Old 06-03-2007, 07:19 PM   #1
abadsvt
abadsvt's Avatar
Another question
I am skining the firewall so i get a nice and smooth firewall when I noticed something. The curved part of the firewall that is right above the back of the motor and the start of the tranny there is a bunch of little dents. I am going to hammer and dolly them out as much as possible but they will most likely require some bondo to get it perfectly smooth. I am worried about the heat from the motor causing the bondo to lift or do something weird. Will it be fine or do i have to do something different? Anyone have personal experience? Thanks alot
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 06-03-2007, 07:52 PM   #2
Robznob11
Robznob11's Avatar
Re: Another question
well personally i don't use bondo brand filler at all becuase of its tendacy to crack break etc. what i do use is fiber hair you can get it at napa and it is green its eather made by 3m or martin senior i cant remember any how it gets alot harder than bondo and bonds to metal alot better, and the good part it sands and works just as easy as bondo only thing is that you need to where a good resperator while sanding cause it does have micro fiber glass in it. they also make fiber strand but it is harder to work and has long strands of fiberglass in it i dont recomend that, if you try the hair i think you will be impressed as i was and probably wont use bondo again. body supply stores also have filler made by evercoat that is aslo much better than bondo. im sure you wont have a problem as long as your hedders are not directly besid the bondo any how and if thats the case the paint is gonna suffer first. good luck
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-03-2007, 08:05 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I wouldn't think that the area in question would be subject to high temperatures. I do agree that there are better products than bondo, though.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-03-2007, 08:17 PM   #4
Robznob11
Robznob11's Avatar
one more thought the fiber hair won't make you itch real bad like you might suspect
LED TAILS
Old 06-03-2007, 08:38 PM   #5
corn
I think when he said "bondo" it was probably just a term not a brand.
corn is offline   Reply With Quote
Old 06-04-2007, 08:04 PM   #6
abadsvt
abadsvt's Avatar
That is exactly what i meant. I call all body filler products bondo. The wierd part is that i have never actually used "bondo products". I usually use short strand kitty hair. Does anyone know how much heat body filler can be subject to. Just want to double check so i don't run into any problems down the road. Thanks alot.
Josh
(Project truck)
Old 06-04-2007, 10:02 PM   #7
Bamm
Cowboy Fan for Life!!!!!!
Bamm's Avatar
I don't know if it answers your question or not, but the P.O. of my truck used bondo to try to stop a timing chain cover leak, the bondo stayed on there for a long time until I found it. It didn;t flake off, I had to chip it off, and no it didn't stop the leak either. .............Bamm
1967 ShortBed Fleetside
3/4 Drop 350/700R4
Tilt wheel
18 x 8 Torque Thrust II's
Future mods: All new gauges & wood bed
My Zip is 23002
I ship UPS, USPS
Bamm is offline   Reply With Quote
