Old 06-03-2007, 08:06 PM   #1
smackmatic
smackmatic's Avatar
Pics of my 67 5.5/7
I finally installed my lowering kit. I used 2.5 drop spindles from gmc pauls and 3in springs in the front, with 5in springs in the rear and a 2in block. There was only a 1/2in between the frame and axle, so I ended up raising the rear an inch. These pictures are before I lifted the rear.
smackmatic is offline   Reply With Quote
Old 06-03-2007, 08:12 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Pics of my 67 5.5/7
looks nice
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-03-2007, 08:21 PM   #3
nvrforgotten52
nvrforgotten52's Avatar
that is a sweet stance. i love the really low static drops! i did a 21/2 drop spindle with three inch springs in front and a three inch block with a four inch spring in the back...
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 06-03-2007, 08:47 PM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
thats awesome man, i like it
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-03-2007, 09:39 PM   #5
dave2953
Dave's not here, man
dave2953's Avatar
Looks really good; how does it ride? I'd like to lower mine some more eventually.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-03-2007, 10:20 PM   #6
68 P.O.S.
That's the stance I'm going for as well. I have 3" springs in the front and I'm waiting for some money to fall outta the sky so I can do the dropped disc conversion. In the rear I have 5" springs and 3" blocks.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-03-2007, 11:06 PM   #7
Shane
Shane's Avatar
bad ass driver bro!
Shane is offline   Reply With Quote
Old 06-04-2007, 08:05 AM   #8
smackmatic
smackmatic's Avatar
Unless you notch the frame you cant really drive it. (I have pics of the how close the rear is to the frame, but they files are too large)
I am not very impressed with the disc brakes either. I ran them with the metering block for drum brakes and they were OK. Then I installed the proportioning valve from cpp and now it is harder to stop than when it had drum brakes.
Old 06-04-2007, 08:55 AM   #9
70c10
67-72 Addict!
70c10's Avatar
I'm glad you posted a pic showing this drop on 15" tires . I just went with the same dropped spindles and I'm thinking about going with a 1.5" spring up front and adding a 2" block in the rear for a 4/6 drop . I installed a prop valve off a 71' truck and my brakes feel worse than the drums also . My peddle is much harder now.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 06-04-2007, 09:07 AM   #10
smackmatic
smackmatic's Avatar
My truck has a6cyl, and three speed. If it had a v-8 with an auto, I think it would sit lower in the front.
You cant tell in the pictures, but it is sitting about a 1/2 in lower in the rear than the front.
I guess if you switch to disk brakes, you really need to install a power booster to get any real stopping power.
Old 06-04-2007, 10:13 AM   #11
70c10
67-72 Addict!
70c10's Avatar
I do have a power booster. I'm thinking my leaking rear wheel cylinder might be contributing to my problem though.
Jim
Old 06-04-2007, 04:17 PM   #12
powell72
powell72's Avatar
That looks *****in'. Too bad the rear needed to be raised up.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 06-04-2007, 06:17 PM   #13
tshaw72low
tshaw72low's Avatar
Nice looking truck..
Thats same setup I have with notch... ride is really nice..
tshaw72low is offline   Reply With Quote
Old 06-04-2007, 09:30 PM   #14
smackmatic
smackmatic's Avatar
I may invest in the notch and some different size tires. The fronts are rubbing the inner fenders.
Old 06-05-2007, 12:03 AM   #15
Rokcrln
Rokcrln's Avatar
Get some front rims off a van! Same style but 6.5" wide so they suck in about an 1" more than yours right now.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 06-05-2007, 01:57 AM   #16
c-mack
c-mack's Avatar
looks good man.
1967 chevy truck
350 V8
1973 VW Transporter/Hippy Bus
1964 VW Baja Bug
"When the power of love overcomes the love of power the world will know peace"- Jimi Hendrix
c-mack is offline   Reply With Quote
Old 06-05-2007, 04:40 AM   #17
GREASEMONKEY72
Kevin
LFD Inc.
and you get the same look and better mpg with skinnier tires
-steven
Alte Seele S.S.
