Old 06-03-2007, 09:00 PM   #1
brawley
Easy Does It
brawley's Avatar
LED lights for dash ?
I've got a 65' chevy.Has anyone used LED lights in there dash cluster on these? Seems it would brighten it up a bit, but im not sure if original harness would power them correctly? Also how do you reset the odometer on these back to 0. Any ideas for something diffrent in the dummy gauge housings? Thanks.
brawley is offline   Reply With Quote
Old 06-03-2007, 09:10 PM   #2
LILRED66
LILRED66's Avatar
Re: LED lights for dash ?
I think LEDs will emit to much light inside the cab and make it difficult to see out the windshield. Might be a good experiment.
To reset the odometer, pull the dash cluster out of the dash, pull the dash bezel off of it and remove the three 1/4" hex screws to release the odometer from the dash cluster housing. Once removed, you can manually manipulate the number disks on the odometer and reset to zero. It is a little tricky, but I have reset several with not much problem.
LILRED66 is offline   Reply With Quote
Old 06-12-2007, 07:13 PM   #3
Ham-er
Depends on what you use for the LED's. If you use modern high brightness ones that are made to replace bulbs then it should be bright!. However if you only want led idiot lights which dont burn out like a bulb will, then use the regular old leds from radio shack or any supplier of electronic parts. You will need to add a voltage dropping resistor to each led though. Also DO NOT replace the generator warning light with either type led. Your alternator needs that bulb to limit it's field current (unless your are switching to a one wire alternator)!
Ham-er is offline   Reply With Quote
Old 06-12-2007, 08:24 PM   #4
baddawg65
baddawg65's Avatar
I've thought about trying these. http://www.whitegauges.net/products_list.php?catID=4550
baddawg65 is offline   Reply With Quote
Old 06-12-2007, 09:32 PM   #5
LILRED66
LILRED66's Avatar
baddawg65:
I just ordered a few of these. I want to see how they work and look in one of my '64-'66 Chevy trucks. Thanks for the link.
Tony
Old 06-13-2007, 08:06 AM   #6
baddawg65
baddawg65's Avatar
Let me know how they turn out. I'm going to try the white guage kit too. The guages for the 4-5-6 are still cheap enough that I cam afford to screw one up. And if it wasn't hard enough to choose a color to paint the truck, now I have to decide what color of guages.
Old 06-14-2007, 12:11 AM   #7
55dude
55dude's Avatar
pretty reasonable and bolt in changeover. less than $20 bucks and your rolling. be sure and post some pic's of the swap.
55dude is offline   Reply With Quote
Old 06-14-2007, 11:29 PM   #8
ClassicAutoResto
Rust Buster
ClassicAutoResto's Avatar
Way cool! no where near ready for dash lights but I gotta have them. Thanks for the link!! Jerry
ClassicAutoResto is offline   Reply With Quote
Old 06-29-2007, 03:55 AM   #9
19GMC63
19GMC63's Avatar
what's the update on this?
19GMC63 is offline   Reply With Quote
Old 08-13-2007, 11:20 PM   #10
19GMC63
19GMC63's Avatar
Old 08-13-2007, 11:33 PM   #11
brawley
Easy Does It
brawley's Avatar
I just reconditioned my instrument cluster. I used whitegauges.com purchased the new background kit ,I also purchased LED lights for the cluster.They come in various colors. It looks alot better,like new. The lights are not as bright as I thought though. I will try to post a picture if I can .This is a good and cheaper way to clean up your cluster without having to change over to new gauges.
Old 08-13-2007, 11:40 PM   #12
1LoC10
Insert Title Here
1LoC10's Avatar
not the same year, but here is what I did
http://67-72chevytrucks.com/vboard/s...d.php?t=196815
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 08-14-2007, 12:08 AM   #13
04Xrider
Registered thread killer
04Xrider's Avatar
I have all led lights, and they do not put out that much light. I used the white face kit with green led's. I also replaced all the blinker indicator, bright light indicator heat/cold and volt lights with the appropriate color led's and replaced the old color covers with milk jug plastic.
!966 stepside, 350 SB, ZZ-4 roller, Crane roller rockers, 0.030 flat tops, airgap intake, 750 Holley, stainless steel headers, edelbrock SDT mufflers, Mark 8 elec fan, 700R-4, column shift
04Xrider is offline   Reply With Quote
Old 08-14-2007, 04:28 AM   #14
fercho71
fercho71's Avatar
that looks nice 4xrider i just got mine from white gauges i will post some pics soon
1966 chevy c-20 truck " La Chata " under construccion
fercho71 is offline   Reply With Quote
Old 08-14-2007, 04:50 AM   #15
Stepside65
Still Truckless!
Stepside65's Avatar
very nice... not a terrible fan of the white tho.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 08-14-2007, 09:06 AM   #16
60ratrod
yes, i do
60ratrod's Avatar
seeing as how i have individual round guages for my guage cluster i'm thinking of getting a custom bezel made outta polished engraved copper
60ratrod is offline   Reply With Quote
