Old 06-03-2007, 11:48 PM   #1
CG
BlahBlahBlah
2 barrel carb question
I was just sitting here thinking I forgot to pull the carb today in my recently acquired 67 with 283 and 2 barrel. I was going to rebuild it myself but had decided to just have it done.
A little lightbulb (tiny) went off in my head...I have whats left of a 65 GMC with a V6 sitting there with a rebuilt 2 barrel carb on it. Does anyone know if this carb would work with my 283 without any weird linkage or any other problems for that matter?
Old 06-04-2007, 09:25 AM   #2
CG
BlahBlahBlah
Re: 2 barrel carb question
Ttt
Old 06-04-2007, 09:04 PM   #3
CG
BlahBlahBlah
Wow all these truckaholics and no one knows?? Guess I will just have to try it and see.
Old 06-04-2007, 09:52 PM   #4
brak
brak's Avatar
I know for a fact i replied to this last night WTF
Do the two carbs look similar? do they share the same mounting pattern?
if they are similar, throw it on, and try it out. Worse comes to worse, you waste an hour or two, take it back off, and throw a rebuild in the one you are currently running.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-04-2007, 10:02 PM   #5
CG
BlahBlahBlah
lol..dunno what to tell you brak. The GMC isnt at my house and the Chevy is. I was hoping to save a trip but it looks like I need to get off my lazy rear and go take it off and bring it home.
Old 06-04-2007, 10:06 PM   #6
Morgsie
The jetting will be different... The time you spend trying to get the 65 carb to work you could probably rebuild the one you have which is not only the correct one for the truck, but has the right jetting, etc.
Morgsie is offline   Reply With Quote
Old 06-04-2007, 10:11 PM   #7
brak
brak's Avatar
hooray, somebody with some actual knowledge on the subject.
a rebuild kit would probably be cheaper than the gas it would take to drive and get the other one anyway
Old 06-05-2007, 01:21 PM   #8
68speedalert
Semi-Senior Member
68speedalert's Avatar
If memory serves me correct, they are different carbs altogether. The 67 likely has a rochestor 2GC while the GMC likely has a Stromberg. That being said, it still may mount up.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
