Old 06-04-2007, 03:15 PM   #1
cory321
Problem Child
cory321's Avatar
r-12->r134 conversion
anyone every tried one of the conversion kits they have at autozone.when the po hooked the a/c up he never charged it.Was wondering if the kits were any good
1972 gmc sierra grande
350/350 a/c soon`to get a new 350
I Survived Norwood
cory321 is offline   Reply With Quote
Old 06-04-2007, 03:18 PM   #2
Jim_PA
Re: r-12->r134 conversion
I did it to my 84z28 years ago. I remember it being pretty straightforward. If I remember correctly, the oil you need to buy to fill the compressor is pretty spendy.
Jim_PA is offline   Reply With Quote
Old 06-04-2007, 03:38 PM   #3
cory321
Problem Child
cory321's Avatar
The kit i was looking at was 35.00 and had supposedly enough refridgerant included
I Survived Norwood
Old 06-04-2007, 03:46 PM   #4
cory321
Problem Child
cory321's Avatar
Its says it has 3 cans of refridgerant 1 can of conditioner and a can of leak detector
I Survived Norwood
Old 06-04-2007, 03:50 PM   #5
Jim_PA
I'm not talking about the refrigerant -- this is the actual oil used to fill the compressor.
Maybe they are implying now that you can just use the regular stuff, but about 10 years ago, I remember I had to change the compressor oil.
Old 06-04-2007, 04:12 PM   #6
cory321
Problem Child
cory321's Avatar
I'll have to check that out
I Survived Norwood
Old 06-04-2007, 07:59 PM   #7
sodak69c10
sodak69c10's Avatar
one thing you have to know about refrigerants is that r-12 used a mineral oil that suspended its self in the refrigerant and the pumps were desighn to lubricate with that oil,but there are r-134 compatible oils for r-12 components, some of your overthe counter kits can contain "filler additives" and can do damage, i a firm believer that it is a good idea to take it to an ac shop and have them charge it because they will have the proper oils/fittings/tools and they will be able to evacuate your system and check for leaks then fill it
just my two cents worth
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 06-04-2007, 10:24 PM   #8
Jim_PA
Yeah, what he said I went out to check the fluids cabinet, and to my surprise, I found what I used "back in the day" -- It's called Ester 100, and says on the back of the bottle it's to be used in R-12 and r-134 systems. I don't see the harm in doing the work yourself, but at the same time, it's kind of a crap-shoot. It will either work and you'll be happy, or you'll have a leak, and it won't last that long... then you'll probably want to have it vacuumed and leak-tested at a shop.
I think I paid about 35 bucks for a quart some time ago, but it looks like the price came down a bit, or I got robbed: http://www.sjdiscounttools.com/cas6808.html
Old 06-04-2007, 11:00 PM   #9
sodak69c10
sodak69c10's Avatar
ESTER oils!! that was the term i was trying to remember thanx, most systems now use PAG oils(they kinda like a sponge they absorb water and shouldn't be exposed to air very long)
,Clint
Old 06-05-2007, 03:50 PM   #10
cory321
Problem Child
cory321's Avatar
I found a coupon for a "free" a/c performance test at midas probably take it there and have it tested
I Survived Norwood
