09-15-2002, 01:25 AM | #1 |
Setting timing with cam advanced
Is there any tricks to setting the timing when you advance a cam, the one in my motor is 2 degrees, and I have been having a tuff time getting it right, I should go buy a light, I got a vacume gauge.
Thanks Taylor
'72 S/S Chevy- in progress |
09-15-2002, 01:15 PM | #2 |
Anybody???
09-15-2002, 01:47 PM | #3 |
Advanced/retarded cam shouldn't make ignition timing any harder to set, and if all you have is a vacuum gauge, go for it. You want the highest vac reading @ idle, with the steadiest needle.
Drive it, after setting the timing as above, listening for knock/ping/ under acceleration. If knock is heard, back off timing a little. A timing light is good investment, but maybe one could be borrowed, or even rented if $$$$ is tight.
1970 long fleet, 355 4 speed, primer, walnut goodies |
