Old 06-04-2007, 06:03 PM   #1
guf
new powerbrakes and now a problem
so i installed new booster, prop valve, and mc and bench bled the mc. when i went to bleed the lines the passenger rear continued to have bubbles, so i went the the driverside rear and didn't get anything no air or brake fluid. when testing the pedal is spongy the rears grab and unsure about the front. what do you think?
guf is offline   Reply With Quote
Old 06-04-2007, 06:06 PM   #2
68 P.O.S.
Re: new powerbrakes and now a problem
Keep trying. When I replaced my rear lines and cylinders, it took awhile before I got any fluid through there. You could try to gravity bleed it as well. Make sure there is enough fluid in the MC as well.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 06-04-2007, 06:35 PM   #3
guf
well now i at least have fluid on both sides and lots of air. gravity bleeding now....
Old 06-06-2007, 09:09 AM   #4
68 P.O.S.
Did everything work out?
