replacement rocker quality ?
I'll try this on this board because it seems like everyone roams here and not paint and body. These are Triplus rockers do all the brands have these lines on them from the bender? This is the part you would step on. I'm curious what the other brands look like.
Re: replacement rocker quality ?
mine are perfectly smooth, but i got them from certifit...
light skimming of body filler, or a couple coats of primer, and i doubt you'd even know those lines were there ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
I`ve never seen that on Tri-Plus rockers.Must have been a bad run.From all I know,Tri-Plus is the best rocker you can get.Definately heavier.
#4 | |||
Union Electrician
Mine are the same way, and I have 2 sets just alike. Sucks don't it? Get a new part to avoid more work and end up with more work than you hoped for
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
![]() Join Date: Aug 2005
Yep, Mine have the same. From Triplus too. I don't think it's a big issue personally.
I have Tabco patch panels on my trucks and love them! Never had any problems with them.Made in the USA too!That's the only company I will use for body panel replacement.
Those rockers don't look to bad though,they can be fixed. Last edited by 1969k10stepside; 06-05-2007 at 12:01 AM. |
![]() Join Date: Nov 2006
i,d return them
Mine were like that too but since I will step there anyway didnt care. Mine were triplus to from 2000, when I bought them.
nothin you cant fix or just leave, could always put grip tape over it
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME Last edited by GREASEMONKEY72; 06-05-2007 at 03:21 AM. |
I was just looking at some compared to thers and all I noticed was how much nicer the Tri-Plus were.I wouldn`t want to have bondo in a wear area like that.I`ll have make sure to only buy ones I`m holding.I`ve only used GM parts before.
It is an easy fix but if Triplus makes Goodmark I'm suprised Goodmark would approve. This is the main part of the rocker you see.
Goodmark quality is a joke---they just repackage and add a premium. Aftermarket rockers tend to be about 1/4 inch shorter too so when you install, tack first then close the doors to make sure you have the proper clearance---it is most noticeable when you seam the front and rear against the A and B pillars.
#13 |
Goodmark was selling doors with the window frame 3/8" too high.They finally changed them.
