Old 06-04-2007, 09:34 PM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
Rear shocks with a 4 link question
So I'm putting a 4-link into my 59 and have a question. I'm running out of room to mount the top of the shocks between the inside frame rails ( possible interference with the panhard bar) and wondered if I could mount the top of them angled towards the rear of the truck on the outside of the frame. Is there a max min angle for them to work properly?
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 06-04-2007, 09:59 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Rear shocks with a 4 link question
yes, I mounted mine that way. I have heard 22* is the max angle
dwcsr is offline   Reply With Quote
Old 06-06-2007, 11:22 AM   #3
Kontrol Phreaks
Kontrol Phreaks's Avatar
Depending on where they are located at now, and how the 4 link is installed you should be able to move them without a problem. If you do angle the shocks towards the rear of the truck then you'll want to make sure the shocks will have enough travel. Remember that the rearend will want to swing away from the shocks when you air up.
If there is any other information or suggestions I can help you with please let me know.
Clint
Kontrol Phreaks is offline   Reply With Quote
