Old 06-04-2007, 11:39 PM   #1
allen1364
1966 C-10 Rear End
I HAVE A 12 BOLT REAR END WITH 4:11 GEARS ,WITH A 6 HOLE PATTERN. AND THE QUESTION IS HOW CAN I CHANGE THE BOLT PATTERN WITHOUT CHANGING THE REAR END,CAN I CHANGE THE AXLES OR DRILL NEW HOLES ? CAN YALL HELP ME THANK YOU
allen1364 is offline   Reply With Quote
Old 06-05-2007, 12:02 AM   #2
hewlett2002000
hewlett2002000's Avatar
Re: 1966 C-10 Rear End
4:11 huh? that stock? i dont recall ever seeing 4:11 gears in a 64-66 truck.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-05-2007, 02:56 AM   #3
LILRED66
LILRED66's Avatar
3.73:1 was the factory 12 bolt rear end installed in the '64-'66 Chevy C10 series trucks. I have purchased a 3.08:1 posi on eBay and I see them on there frequently. They sell the entire master set up kit. I think I paid in the neighborhood of $375-$400, plus shipping. Do a search for 1966 Chevy Truck and check the search Title and Description box. There will be 1,500-1,800 auction items results. Sift through them and you will find one. Good luck with your gear swap.
Tony
LILRED66 is offline   Reply With Quote
Old 06-05-2007, 07:26 AM   #4
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
allen1364, Early Classic Enterprises sells 5 lug axles that will fit your rearend. They are 5 on 5" pattern like the later model trucks. Check their website. Kevin
65StreetCruiser is offline   Reply With Quote
