Texas Big Wig
My truck squeaks like a rubber duck on roids !!!
Like the title says, my truck squeaks really really bad
It's all coming from the front end, what do I need to do to solve this It squeaks going over bumps & it'll even squeak when you steer it while sitting still Help !!! Last edited by Spray-Bomb; 06-05-2007 at 01:39 AM. |
Re: My truck squeaks like a rubber duck on roids !!!
spray bomb filled with lubricant and sprayed in the general direction of squeaks sometimes helps/ then theres also whats called a grease gun
That`s what it sounds like.Your front end needs a lube job.Time to slap some grease into those zerks.Hopefully they`re not froze up from lack of use.
Sandwich: Club
make sure your kick panel vents are closed too. Mine squeak like hell when they're open...gotta get some silicone spray on those someday....
Mine does it really bad too. I greased all but 1 fitting and it still sounds the same. So i dont know what to do.
'67 C20 Lwb 350 4-Speed '01 Chrysler Concorde LXI (wifes ride) '91 Gmc Suburban 3/4 2wd 454 Tbi '51 Jeep Cj3a "Willys" 350 V8 |
Texas Big Wig
I thought thats all I needed to do, I just wanted to know for sure
I'll try and get under there today & get all that I see greased Thanks guys |
They're 40 year old trucks? Grease all fittings. Look for loose stuff under there. If all is good, turn up the radio
![]() That said, my truck doesn't have any squeaks at all, but she does have rattles ![]()
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Texas Big Wig
No radio
![]() But I do have loud exhaust & you can still here them over that ![]() |
spray silicone lubricant at the upper A-frame bushings. Assuming it is a 2wd.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Jack the truck up by the frame (not the A-arm) and check for excessive movement/wear. Your balljoints or other suspension parts could be bad.
I had a Chevelle that did the same thing... it was the A-arm bushings.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Dave's not here, man
Mine squeaked like yours; I just finished replacing all the front end parts and bushings and no more squeaks. Hopefully yours is a simpler fix.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
#13 |
a suspension rebuild erased my squeaks too.
#14 |
Can you make it squeak by bouncing it? If so, get under the hood and get someone to bounce it while you try to home in on where it's coming from. Might have to get underneath the front end, also.
Spray-lube diagnosis is possible, but be sure you use the proper lube if you find something squeaking. Wouldn't want to lube steel A-frame bushings with WD-40, right? Not permanenly, anyway. |
#15 |
Active Member
![]() Join Date: May 2005
Agree with above: Upper A-Arm bushings was where my squeak was. Put the front of the truck on jack stands (Wheels off ground), this will let you get to all the zerks a little easier, and gets more grease into all those moving parts by taking the load off.
J
Cadillac Powered |
#16 |
Texas Big Wig
Thanks for all the tips guys
Yesterday I got under it & greased / lubed every thing I could see It helped a lot, but it still squeaks So I think I'll try some of the suggestions above I really hope I don't have to rebuild me front ![]() |
#17 |
Active Member
Mine went away after the front end rebuild, but now I can hear the hood springs (I Think?!) sqeaking. <sigh> Oh well, atleast its not nearly as loud, or annoying!!
J
Cadillac Powered |
#18 |
Texas Big Wig
Well I'm gonna rebuild my front & bag it soon, so my squeaks shall be all gone soon
#19 |
something else to think about and check, coil springs will sometimes squeak once they become worn on the ends that go down into the lower control arm and the upper end that goes up into the crossmember.
#20 |
chrome makes it go FASTER!
scary story I was checking out a friends 69 and it squeaked when he turned the steering wheel. We found a broken bolt on his steering box and the other two were loose. He had just driven 50 miles on the interstate! Lucky man.
She can't cook and she won't clean. But she looks good in a skirt and she brings me beer. She can stay for now. EDIT:: But she left me anyway, So forget her. 1962 GMC Stepside V6 4 speed My rolling resto thread http://67-72chevytrucks.com/vboard/s...d.php?t=324226 My old farm truck http://67-72chevytrucks.com/vboard/s...=1#post3465005 |
#21 |
Active Member
poly bushing will squeak if they arent lubed when installed
also does it do it when turning or when u hit a bump? |
