09-15-2002, 12:00 PM | #1 |
Running on empty
New to board - need some help
I registered to this board 2 weeks ago and haven't been able to "log-on" at home since; I am able to log-on at work(that's where I am posting this message from(Sunday Morn) and obviously my boss wouldn't appreciate me spending company time here); when I log-on at home the area at the bottom that shows active members recognizes my username; but the top of page does not show me as being an active member nor does the "Log-out" option appear at the bottom of the page; I have followed the procedure that Josh recommends under the Logging In Problem sub-directory and delete all the 67-72 cookies and this still doesn't help; I have set all my Internet Explorer options at home to match my work computer and that didn't help either; my Systems Administrator at work is stumped also; I'm not the smartest when it comes to computers; any suggestions?
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver |
09-15-2002, 12:35 PM | #2 |
Carolina Classic Trucks
I was having the same problem ealier last week after I bumped up the the privacy level in Internet Explorer 6.0. I had to set it back to the medium setting in order to log in and have my name appear at the top with the others. Hope this helps.
Ryan
09-15-2002, 01:13 PM | #3 |
Welcome to the Big Show
A BIG welcome from S.C. let us know if we can help you anyway.
Things happen for a reason! |
09-15-2002, 01:16 PM | #4 |
December 21, 2012
Did you mess with the cookie options under the edit option under the user cp? This may have caused your problems.
I messed with this and I then had the same problems as you do. It turned out to be the browser I was using. I'm on aol and the browser does not work well with vBulletin board systems, it turns out. I got logged on to the net then changed my brower to the internet explorer one on my computer and then accessed this site then logged in and the site then reconized me. After that I was able to switch back to my aol browser and have had no problems yet except for voting in polls which then I must use the internet explorer browser to be able to vote.
"!Ama Sua, Ama Kjella, Ama Lllulla!" |
09-15-2002, 02:00 PM | #5 |
Running on empty
Hey thanks Maximum Overdrive, that worked like a charm; went to my Internet Explorer and logged in no problem; I appreciate the help; Now if I can just find the right truck............
