Old 06-05-2007, 12:25 PM   #1
70ChevyCST
70ChevyCST's Avatar
Gasoline smell in cab
Hi guys,
I already did a search on this topic here and read "Fuel Smell in Cab" by spdrcr29 in March of 07. There seems to be no consensus here...about half said it's normal because the gas tank is right behind the seat and the other half said check the sending unit gasket, vent connections, filler cap etc. Well I have a newly frame off restored 70 CST-10 fleetside longbox and the seller left several bugs for me to swat. The next bug for me to squish is this gas smell problem. I do not want to move the tank. I've inspected behind the seat carefully and have seen no signs of seepage...There's a new tank, sending unit and cap. There is no vent on this tank which surprises me! I'm thinking there's a new sending unit gasket if there's all these new parts here....but I will obviously check this now...But here's my question: In the LMC parts catalog I see a cardboard tank cover and a tank cover carpet are available. Could this be why I'm still smelling gas? The restorer did not spring for either of these items. Also: The tank is still bare metal. Should it be painted? Oh yes...smell is worse when tank is full. Thanks everyone in advance....
Bob
70ChevyCST is offline   Reply With Quote
Old 06-05-2007, 12:34 PM   #2
69rut
Re: Gasoline smell in cab
Isn't there a joint between the filler neck and the tank?
I don't think carpet will help. If you have this smell now, think how much worse it could be once the carpet absorbs the oder.
trailers are for boats
69rut is offline   Reply With Quote
Old 06-05-2007, 12:50 PM   #3
mrein3
mrein3's Avatar
You probably have a 1972 cap on a 1970 tank. Or vice versa. In 1972 they went to a vented system. Before that the vent is the cap.
Try a new cap.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 06-05-2007, 02:40 PM   #4
sodak69c10
sodak69c10's Avatar
try a new gas cap, you said that the tank isn't vented, if you have a non vented cap the heat in the cab on a hot day could cause the gas to expand an start to seep out where ever it can, might be a good idea to check and the pinch weld around the tank for moisture
one way to check is on a hot day after it sits go crack the gas cap and listen for a loud hiss from excessive pressure, if there is pressure in the tank it might help you locate a leak to because it would open up the hole
on kind of the same note of vented caps, in the summer time i don't fill my tank over 7/8 full because if it sits the heat makes it expand and run out my gas cap vent, i found out the hard way my cap wasn't venting it broke the welds that hold the pick-up tube in the sender and when the tank was full it leaked , i found the leak sanded paint/dirt out of the area leaking and filled the hole around the tube with jb weld and then got a vented cap that was a year ago and no smell anymore
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 06-05-2007, 02:50 PM   #5
72freak
Rottenwood Garage Member
72freak's Avatar
i didnt read everything.........but.....here are a few.........
vented cap, cracked gasket between tank neck and cab hole, sending unit o ring or a pin hole in the tank.
72freak is offline   Reply With Quote
Old 06-05-2007, 02:55 PM   #6
riche
New Member
And last but not least... If you put any pressure on the fuel line exiting the sending unit. It can make a small hair-line crack around the hose. It will leak a little though when the tank is full. Not enough to fill up the cab with gas. But enough for you to see.
1969-72'ish C-10 SWB Step
1997 Chevy Z71(sold)
2005 Chevy Crew Cab
riche is offline   Reply With Quote
Old 06-05-2007, 05:20 PM   #7
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
I've got the same problem on my '70 haven't solved it yet - put about 1 PSI pressure into it to see if it would hiss but nothing found. My old '66 and '64 had tank in cab and no gas smell , it is really worysome smeling gas inside what happens if there is a static spark ?
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
