06-05-2007, 01:19 PM | #1 |
Grand PooBaa Member
CPP Axles
I remember seeing that someone in here had a few problems with CPP Axle conversion kit. Does anyone remember what the problem was?
Need to know before I make a purchase. |
06-05-2007, 01:33 PM | #2 |
Junior Member
Re: CPP Axles
I dont know about any problems but i used on my 67 c10 2wd and so far have had any problems
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi |
06-05-2007, 01:44 PM | #3 |
Re: CPP Axles
This is the responses that I got when asking the same type question. Might help.
http://67-72chevytrucks.com/vboard/s...d.php?t=239131
'69 short step with dreams of being a hot rod You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. |
06-05-2007, 02:31 PM | #4 | |
Grand PooBaa Member
Re: CPP Axles
Thanks guys, I knew I had read a something. What im finding is most of the axles shipped are not including the studs, and bearings. And by the time I put it all together, I could drive down to CPP and just pick up the kit. I pieced together the disk brake kit and only save a little money, so I think im not going to skimp on the axle kit. |
