06-05-2007, 03:11 PM | #1 |
Best degreaser?
What's the best degreaser to use when cleaning up under to hood? Need to get the oil, dirt and other fluids that are caked together off so I can look for some leaks (mainly in PS). Also, are there any drawbacks like eating paint, affecting rubber, etc? Sorry for all of the questions, guys.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
06-05-2007, 03:24 PM | #2 |
Re: Best degreaser?
If it's "fresh stuff" like a recent leak, some wd40 and rags should clean it up. Not sure what to use on old caked on stuff? I've always used a scraper and pressure washer, but thats probably not an option in your case
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 06-05-2007 at 03:25 PM. |
06-05-2007, 03:34 PM | #3 |
Re: Best degreaser?
I like to use Super Clean, formerly made by Castrol. It works very well full strength, and I've had no issues to date with compatibility with paint, etc...as long as it's very thoroughly washed off
http://www.superclean.com/index.php |
06-05-2007, 03:53 PM | #4 |
Re: Best degreaser?
I like to use easy off oven cleaner, but you do have to be careful around paint. Also, make sure you use some rubber gloves, it can give you a pretty good chemical burn; don't ask me how I know.
Ronnie
1968 C10 Stepside 396 bored .030 TH400 |
06-05-2007, 04:18 PM | #5 |
Son of a gun
Re: Best degreaser?
the other guys made some good suggestions, I'll put my $.02 in too:
On general clean up and not really tough stuff I like purple power, or any of it's generic counterparts that usually have purple in the name. I have good luck with all of them, they cut grease and oil really well.
Bill BEATERS ARE NEATER |
06-05-2007, 04:29 PM | #6 |
Prestige member Old Farts Club
Re: Best degreaser?
castrol super clean is a diluted oven cleaner if you want to go that route, I've used it before works real good just WEAR gloves , I just use gunk engine bright and a pressure washer for the major cleanup
Hey sombodys gotta do it! |
06-05-2007, 05:12 PM | #7 |
Re: Best degreaser?
I'm with the Super Clean crowd......good stuff, just keep it off aluminum.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
06-05-2007, 05:18 PM | #8 |
F.A.S.T. president
Re: Best degreaser?
Formula 88, just dont let it sit on old paint to long. But any kind of CRC type spray lube does a good job on soaking in and loosing it up before hand.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 06-05-2007 at 05:20 PM. |
06-05-2007, 05:21 PM | #9 |
Re: Best degreaser?
i like simple green.....
06-05-2007, 05:33 PM | #10 |
Re: Best degreaser?
A product that I like and have used for years is "Oil Eater". I get mine from Napa auto parts and now I just buy it in a 5gal bucket. They also sell it in 1gal size. It is delutable but I always use it full strength and have never had any problems. Works great as a floor cleaner and driveway spot remover (for those that want to remove their driveway in spots ) .
Kevin LFD Inc. |
06-05-2007, 05:34 PM | #11 |
Re: Best degreaser?
Home depot sells this stuff called ZEP. It's a concrete cleaner that I used on my engine compartment. It will pretty much take it down to bare metal. Don't use if you are just trying to clean up something that's not going to be repainted though. It's also badass concrete floor cleaner too.
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque |
06-05-2007, 08:32 PM | #12 |
Junior Member
Re: Best degreaser?
I use this stuff we have at the bicycle shop called Finishline Biodegradable Degreaser. It works great on greasy bicycle chains, but recently I used it to clean off the transmission oil, along with other oil residues, and some caked on stuff, but nothing real thick, and it did great. I was impressed the way it removes some of the motor oils, gear oils, and other things that should never be used as bicycle chain lube, but when I was trying it on the engine and transmission I really didn't expect much. I figured the engine heat would make some of it resistant to the Finishline. Boy was I wrong! I spayed it on with a trigger sprayer, turned around to turn on the water, and sprayed it off. I was all gone. Wow!!
Oh yea, it is okay on painted surfaces. We use it on the grease covered bikes all the time. Check it out sometime. Keith |
06-05-2007, 08:33 PM | #13 |
Sierra Grande Club
Re: Best degreaser?
I’ve found Napa’s brand spray degreaser works real nice, cuts grease and rinses off clean.
I have doubts that any cleaner will clean thick caked on grease/grime without scraping or power washing. You’re going to need several cleanings, buy a can of each and let us know! s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 06-05-2007 at 08:34 PM. |
06-05-2007, 09:11 PM | #14 |
Re: Best degreaser?
kerosene will cut the oil / grease and will make your paint shine.
06-05-2007, 10:18 PM | #15 |
Aluminum slot wheels rule...
Re: Best degreaser?
Brake/parts cleaner and a pressure washer. Super Clean works great to clean about ANYTHING.
06-06-2007, 12:39 PM | #16 |
God Bless Mr. T
Re: Best degreaser?
Allow me to jump on the Super Clean wagon. We use it at work and buy it by the 55 gallon drum. Awesome stuff. Works great to get grease and oil off the shop floor.
Like a midget at a urinal...sometimes you must stay on your toes. |
06-06-2007, 03:51 PM | #17 |
Re: Best degreaser?
Looks like I'll have to try superclean, then. Maybe I'll get the zeps to clean her territory markings from the driveway.
06-06-2007, 06:39 PM | #18 |
Cantankerous Geezer
Re: Best degreaser?
Start with a scraper to clean off the thick stuff. It will save you a lot of cleaner.
Fred There is no such thing as too much cam...just not enough engine. |
06-06-2007, 06:52 PM | #19 |
Re: Best degreaser?
Will do, Fred. Thanks.
06-06-2007, 08:32 PM | #20 |
Re: Best degreaser?
While were talking cleaners,how about parts cleaning tanks. I use karosine in my parts cleaner (20gal) and it works OK but my wife won't let me in the house for the smell. Has anyone tried the water based cleaners for the tanks? I feel they will be weak but maybe not.
Anyone using waterbase cleaner?
68 4x4, 454, 4 speed, disk brakes both ends, Sold my 69 SS396 Elcamino when young & stupid |
06-06-2007, 09:39 PM | #21 |
The Original HotRod KnifeMaker
Re: Best degreaser?
Simple green here- the salesman brushed his teeth with in a motor pool demo Must be safe....
Cover the delicate stuff with foil before you start to keep the dry stuff dry- it easily molds to complex shapes and is very easily removed and disposed of. Post some 'cleaned-up' pics with how you did it and what you ended up using.
Dave 69 GMC SWB 2WD 454 Turbo 400 |
06-06-2007, 09:45 PM | #22 |
Re: Best degreaser?
Rent a Steam pressure washer. That will melt away inches of gunk in seconds. Well worth the rental fee in my opinion. I always try to stay away from wd40 and other oil or silicon based products they will haunt you when you move on to painting.
06-06-2007, 09:58 PM | #23 |
Re: Best degreaser?
Yeap, I highly recommend that. I used engine degreaser (GUNK i think), let that sit over night and then pressure washed the next day, worked REALLY good, especially with the engine not in the vehicle. Be careful where you do it for environmental purposes :/
06-06-2007, 10:01 PM | #24 |
Re: Best degreaser?
As for parts washer fluids. I use a low odor mineral spirits(paint thinner). Not alot of prep work for when You are going to paint.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
06-07-2007, 12:38 AM | #25 |
Re: Best degreaser?
As for the parts-washer, I sure wouldn't recommend anything aeromatic like kerosene! I use pure SuperClean and it works great!
