dash pad
when if ever did they change the dash pads? to 73 to 78.i'm thinking of buying that one that scott has, but he says it might not be the same as an 88 i have a 1988 surburban that i need a dash pad for,was wondering if the one scott has for sale will work.because i'm in going to send pay-pal for it but don't want to buy it and it not fit my 88 burb.
Junior Member
Re: dash pad
For pickups 73-80 are the same 81-87 are the same.The pad he has won't fit on your burb.An 81-87 pad for pickups will work on 88-91 blazers and burbs.The differances are very noticable,contour,defrost vents,the insert above the glove box,and the early pads would cover the vin. tag on later models.Hope this helps and good luck.
Scott C. 84 Custom Deluxe(under Construction) 87 Buick Grand National 91 Gmc Sierra daily driver |
![]() Join Date: Oct 2004
Re: dash pad
Kurt I have one on ebay that will work. I will give back 10% of the price if a site member wins the auction. You wont find a better dash pad anywhere, this pad will never crack again and I have them installed in all 3 of my trucks. I can provide more pics if you want it just gets expensive on ebay. Item #;
170119165511
Dissabled Veteran U.S.M.C 1985-1989 |
Re: dash pad
How will it never crack again? You said in your response on the other thread they were better than OE. Are these refurbed stock dash pads or are they aftermarket?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: dash pad
you need an 81-91 dash. We have GM 81-91 dashes still in the box for sale:
http://store.73-87chevytrucks.com/me...tegory_Code=DC
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Re: dash pad
thats not what i'm looling for. that looks like carpet on there don't want something like that.thanks anyway john 39671.
Re: dash pad
Kurt it is not carpet but a marerial that us used in speaker boxes. The top is sealed before it gets covered so it cannot crack. It may look like carpet but it does not act like carpet.
