Old 06-05-2007, 09:02 PM   #1
Lated
Lated's Avatar
Radiator ?
I'm looking at putting a 4-Core big block radiator in my truck. Will it work with a small block or will I need to make some changes? Should I use the Big block fan shroud or the small block?
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown
'70 SWB Step-Side (More rust than metal)
Lated is offline   Reply With Quote
Old 06-05-2007, 09:33 PM   #2
Sammy
Re: Radiator ?
You will need to change the rad mounts ( 4 core) for the radiator and mount your shroud to that radiator, the small block one is fine, I think the big block shroud is for the larger fan which you don't need to change.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-05-2007, 10:02 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Radiator ?
get the mounts from that truck if you can and use them and id keep the sb shroud
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-05-2007, 10:38 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Re: Radiator ?
I think the shroud mounts to the radiator supports on top. So I’m thinking your shroud won’t work with the larger radiator. Can someone confirm this?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
