Old 06-05-2007, 09:24 PM   #1
roughedup72
roughedup72's Avatar
Transmission troubles!!!! need help Quick!!!!!
Hey yall,
I recently turned my truck into my daily driver and today on the way home I noticed that my trans. wasn't wanting to go into third. Any Idea whats going on?it shifts into 2nd fine and then when it reaches time to go to 3rd it stays in 2nd and if I let of the gas it will shift.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 06-05-2007, 09:28 PM   #2
OlChev67
Ever heard of Beech Island??
OlChev67's Avatar
Re: Transmission troubles!!!! need help Quick!!!!!
vacuum troubles maybe?
OlChev67 is offline   Reply With Quote
Old 06-05-2007, 09:36 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
i dont think its vaccum but it could be, check the vac line from the intake to the trans, but i think it might be in the valve body of the trans or even the TQ converter but i could be wrong
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-05-2007, 09:37 PM   #4
71swb4x4
71swb4x4's Avatar
Did you check the fluid level?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-05-2007, 09:38 PM   #5
GREASEMONKEY72
that to
duh to me
-steven
Alte Seele S.S.
Old 06-05-2007, 09:52 PM   #6
roughedup72
Yes, That was the 1st thing I checked. Then I checked the vac. line everything looks good. Fluid level is good and vac lines are good and tight with no cracks. could a piece of trash some how or another got to the vac line and blocked it?
Old 06-05-2007, 09:59 PM   #7
GREASEMONKEY72
its possible something could be clogged
dont take this the wrong way or anything but you did check the fuild with it idleing in park right?
but if fluids good and the vac lines are all good then i think its either the valve body or torque converter
-steven
Alte Seele S.S.
Old 06-05-2007, 10:38 PM   #8
wibilly
wibilly's Avatar
i'd try a modulator.
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-05-2007, 11:21 PM   #9
roughedup72
It wasn't taken the wrong way,Alot people dont know to check the fluid with the engine running and in park. But to answer the question, yes I did.
Old 06-06-2007, 12:18 AM   #10
kwmech
I agree--they are about 10 bucks
Old 06-06-2007, 10:51 PM   #11
roughedup72
It died. I drove to work today and as I left the house this morning it shifted fine through 1,2,&3. After it warmed up it wouldnt shift into 3rd and when I did get it to go into 3 it would slip like crazy.So, out with the old and in with the new. I will be picking up a 700r4 tomorrow afternoon and dropping off my drive shaft to have it reworked. Which brings up the Question. How long does my driveshaft need to be,or how much needs to be cut off of it??
Old 06-06-2007, 11:32 PM   #12
kwmech
To be accurate with the measurement, the trans should be installed THEN measure it
