Old 06-05-2007, 09:52 PM   #1
goldengoat2
power steering on a c20 4x4
I would like to install power steering and disc brake axles on my 67 3/4 ton. what year steering box will bolt into my 67. I have a 84 1/2 ton parts truck, will this year power steering box fit? I would like to keep it a 3/4 ton so i don't think I will use the axles from this truck. thanks for any imput. Rick
65 tripower conv 4spd gto, 66gto, 67 gto
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
goldengoat2 is offline   Reply With Quote
Old 06-05-2007, 11:50 PM   #2
1969k10stepside
Re: power steering on a c20 4x4
You will need to add spacers or dimple the frame to use a power steering box on it.For discs,you can get a conversion kit from Blackbirds,IIRC
Link to Closed Knuckle front disc brake conversion
1969k10stepside is offline   Reply With Quote
Old 06-06-2007, 05:58 PM   #3
goldengoat2
Thanks for your help, Rick
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
Old 06-09-2007, 01:28 AM   #4
earl87gta
earl87gta's Avatar
its way cheaper to just get a d44 front from a newer truck it will bolt right in only thing need to change is brake lines .here is a good post hor the power steering http://67-72chevytrucks.com/vboard/s...d.php?t=227960 we should get Krue or some one to add this to the tech write ups it has links to all the post with pics of diffrent ways to do the power steering convertion in it.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-10-2007, 09:25 PM   #5
goldengoat2
Earl, this is great stuff, thanks, this web sight ROCKS!!! I am going d44, I,m looking in everybodys driveway for parts trucks. Thanks
65 lemans conv 4spd
69 firebird conv.
67 c20 4x4
Old 06-10-2007, 11:37 PM   #6
eedgell
It's the air up here
eedgell's Avatar
Did the 67's not have dana 44's?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-10-2007, 11:41 PM   #7
1969k10stepside
Yes but until 1971 they didnt have disc brakes and until 1970 they had closed knuckle front dana 44s.1970 was the transition year to open knuckle axles,but they kept the drums till 71.67s had a different type of power steering and in 67-68 the frames werent "dimpled" for the power steering boxes
Old 06-11-2007, 11:06 AM   #8
msgross
msgross's Avatar
I heard that GMCPauls has a conversion kit to fix the "non-dimpled" frames like my 68. Not only is it missing the dimple but it doesn't have the raised pads either.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-11-2007, 08:43 PM   #9
earl87gta
earl87gta's Avatar
Yap there is one on the marcket I havent priced it yet but here is the info
Chevy Frame Braces- Part #899-900
To strengthen or repair cracked frames behind GM steering boxes on '73 - '91 full size vehicles. Weld on application.
899 - 2WD Brace
900 - 4WD Brace
http://www.warriorproducts.com/catalog/catalog.php
Earl
