Old 06-05-2007, 11:37 PM   #1
67Mach1
67Mach1's Avatar
Tire Storage question?
I have several 15 inch tires and rims from projects and for future roller needs.
What is the best way to store these tires? Some are mounted on rims others are not. Stack the flat on top of each other? Put them on their treads, lean them over to one side?
Is there anything I might want to spray/ coat/ or treat them with before storage.
Once a tire starts to dry rot a bit is there anyting that can be done to make it stop? or at least to make it look better?
thanks Thomas
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 06-05-2007, 11:44 PM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Tire Storage question?
Found this write-up for you. Hope it helps.
http://www.yokohamatire.com/pdf/tsb-112102.pdf
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-06-2007, 12:04 AM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I recommend storing upright indoors, out of the sun. Everytime I mess with a tire that has been stored on its side I have a bear of a time getting it to seat on a bead because it has lost its shape, and nothing is harder on tires than the sun.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 06-06-2007, 12:17 AM   #4
jimfulco
Tie them up in a big garbage bag to keep the rubber from oxidizing so fast.
jimfulco is offline   Reply With Quote
Old 06-06-2007, 01:00 AM   #5
dubs68SWB
dubs68SWB's Avatar
9 years of tire experience.....If they are modern radials, it doesn't matter a bit. Unless you are mounting them yourself and trying to air them up with a $19.99 roadside inflator that plugs into your lighter, the tire shop will have no problems airing them up. Whether you stack them up or on their sides, it just isn't going to matter! The weight of a vehicle can have an effect over time, but once they get warm from driving, they will be round again. The main thing is always the elements. Keep them out of the weather and the sunshine. Simple!!!!
'68 Chevy SWB with 460 BBC
Muncie M-22 and Eaton posi rear w/ 3.73's
Corvette rallys with mini derby
caps
Sick horsepower and torque
dubs68SWB is offline   Reply With Quote
Old 06-06-2007, 05:34 AM   #6
grayw0lf
Its actually quite easy. Put them on a pallet & ship them to Prattville, AL. I'll make sure they don't sit around & dry rot.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 06-06-2007, 07:31 AM   #7
67Mach1
67Mach1's Avatar
Would you prefer them to be with or w/out rims?
is for sale
Old 06-06-2007, 07:37 AM   #8
67Mach1
67Mach1's Avatar
Great report, Thanks!
currently they are stored stacked in sets of four based on the matching rims (if mounted) I do have a few that are stored standing up so this gives me some direction on how to make sure they last. The tires are indoors in the back corner of a three sided barn(shed) so they are out of direct sunlight.
Thanks again,
Thomas
is for sale
Old 06-06-2007, 11:26 AM   #9
Bus Ted Knuckle
Son of a gun
I wouldn't call my 15cfm 28hp 2 stage compressor "a road side tire inflator"
Yeah, even modern tires will collapse sideways...and it make them a bear to seat the bead
Keep them upright, out of the sun
BEATERS ARE NEATER
Old 06-06-2007, 11:59 AM   #10
sodak69c10
sodak69c10's Avatar
if your rafters are close enough together in you shop set the tires upright over head then they out of the way as well, pluss they inside letting them sit outside in the sun is the hardest on them, as for making them easier to seat(ether) i use to do tires alot when i was in highschool a tire machine with the air injector makes quik work of it (all the tires we kept at the shop, over 50 tires are stores upright on racks)
,Clint
LOUD PIPES SAVE LIVES
69 C-10 short stepside 406 sbc, 02 YAMAHA WR250F, 07 SUZUKI SV650S, 81 Grand Prix 355 sbc, 81 XT 500 YAMAHA
sodak69c10 is offline   Reply With Quote
Old 06-06-2007, 01:52 PM   #11
dubs68SWB
dubs68SWB's Avatar
I wish that my compressor was that one. I guess when I made that comment, I wasn't talking about you. My point was that 90+% of all people will have there tires mounted at a tire stort. The bottom air blasters on all older and newer tire machines can take a pancake thin tire and get it to seat quite easily. I guy could even run a 2x4 thru them and hang them up. I think we are all on the same page though that it's the elements that you have to watch out for more than anything else.
caps
Old 06-06-2007, 10:00 PM   #12
sonnyman28
sonnyman28's Avatar
i live in calera work on maxwell afb, good to hear someone from the area.
sonnyman28 is offline   Reply With Quote
