![]() Join Date: Nov 2005
Vent / Kick panel rust repair ?
Morning
Just wondering if there are patch panels available to repair rusted vent door under the cowl ? I've never seen them listed , anyone know of a source ? I guess they could be cut out of a parts truck . Later ............................................... 409
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
Tightwad
Re: Vent / Kick panel rust repair ?
The best of luck tooo ya....there is none out there just the bottom peice and it does not go all the way up to the vent doors....Mine was rusted all around the vent doors....so i am cutting mine out completely...i will post pics of the before and after when i finsh...Your best bet if you want the vents is too get a donor..
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
409biscayne go toLMCTRUCK.com the catalog that i have has the m thatgo from the floor to the bottom of thvent on the back side and half way up the vent on the front. can't tell though if their metal or the plastic covers. if nothing else use peices of poster board to make a template then cut out the old and weld in the new.
