Old 06-06-2007, 02:49 PM   #1
steverino66
HEI wiring change?
I read somwhere the other day that a 'resistor wire' needs to be changed to wire HEI to an older stock harness. Can anyone clarify this - which wire exactly, and what does it need to change to? Any help appreciated.
steverino66 is offline   Reply With Quote
Old 06-06-2007, 02:53 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: HEI wiring change?
HEI runs off a constant 12 volt.... its needs a 12 volt wire, I just did the swap a few months ago and it runs great
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-06-2007, 03:31 PM   #3
hewlett2002000
hewlett2002000's Avatar
as did i. just take the wire off the stock coil on put it on the + terminal on the HEI.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 06-06-2007, 03:38 PM   #4
CAL 58 GMC
CAL 58 GMC's Avatar
1LoC10 is right. It's an easy install with only one 12 volt wire hooked up, that's what's nice about the HEI's, everything's all in one unit and all it need's is power hooked up to it.
CAL 58 GMC is offline   Reply With Quote
Old 06-06-2007, 04:20 PM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
It is simple. All that is needed is a 14 or 12 gauge wire from the ignition side of the fuse block to the power on the HEI. You don't need the resistor or the bypass wiring from the starter.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-06-2007, 05:21 PM   #6
hewlett2002000
so does that mean i hooked mine up wrong? i just hooked the + wire from my old coil to my HEI. i thought the old coil got 12v?
thanks,
John
Respect:
Old 06-06-2007, 06:48 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Your HEI will work with the smaller wiring and resistor, but it will work better with the wiring change. Especially above 3,000 rpm.
The old coil got about 9 volts, which allowed the points to last longer. You can use and older coil with the HEI, but you need to lose the resistor to allow the HEI to function properly. The bigger gauge wire is because the HEI will demand more current at high rpm. For a V8 12 gauge, for a 6 14 ga is recommended.
Fred
Old 06-06-2007, 06:58 PM   #8
hewlett2002000
well in that case some rewiring is in order. thanks, i always thought the old coil got 12v.
thanks,
John
Respect:
Old 06-06-2007, 07:00 PM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
If it makes it easy you can just hook the HEI wire to the pink wire from your switch.. That carries 12 volts with the switch on..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-06-2007, 10:51 PM   #10
hewlett2002000
well i ran a wire to the ign on my fuse box. i just taped up the original so i could hide it. thanks for informing me of this yall.
Respect:
Old 06-07-2007, 06:06 AM   #11
hewlett2002000
my truck seems to run better with it like that.
Respect:
