06-06-2007, 03:35 PM | #1 |
04 burb bug deflector
I just installed a Lund bug deflector on my 04 suburban and now all from 30-65mph I can hear a high pitched whistle. It's less noticable at higher and lower speeds than that. I absolutely don't want to take it off. Is there anything that can be done to "shut it up"? I think the larger gap between the deflector and the hood on the outer 4" is the culprit.
06-06-2007, 03:39 PM | #2 |
Re: 04 burb bug deflector
what brand bugshield is it?
69 4wd V6 20k orig miles!! 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
06-06-2007, 03:44 PM | #3 |
It is the stainless one from Lund.
06-06-2007, 03:56 PM | #4 |
thats why... those stick out alittle farther than the plastic ones. did you push it in all the way against the hood.
06-06-2007, 04:04 PM | #5 |
I had to bend the tabs a little but I was afraid if it went any more the center tab that's split would pull out from the screw. I put the rubber stops on the hood at the closest point to the deflector per the instructions and they touched. I can try to lean it back a little but I'll have to get a bigger washer for the middle.
Thanks |
06-19-2007, 09:50 AM | #6 |
I read online a while back, I tried to find it again but I can't seem to find it, there was some people having this problem and it is from the different angle the air hits the windshield or something, anyway they put double sided tape between the rubber and the windshield and it stops the whistle. I think there is only a small area you have to do it but i can't remember where it was.
'69 Chevy SWB Fleet 307/350 '09 Z71 crew cab '04 Tahoe (wife's) '07 Yamaha Road Star Silverado |
06-19-2007, 11:11 AM | #7 |
Slots go on anything!
GM offers a heavier windshield molding just for that. It is heavier than the original molding. A lot of times the upper molding has a tendency to make a flapping noise also, edpending on the type of bugshield.
06-19-2007, 05:55 PM | #8 |
On the fast track to nowhere..
You can also try cleaning between the windshield side molding and windshield. Run a light bead of 3M Super Weatherstrip Adhesive between the two. That's what we did until they made the redesigned molding available.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
06-21-2007, 06:56 AM | #9 |
Great info guys. Thanks. I'll try to google "windshield whistle" and see what I come up with.
06-21-2007, 11:03 AM | #10 |
^Go to GM-trucks.com and use their search. But, all the fixes I read on there are the same as the ones already posted. Mine does it too, but it doesn't bother me, I listen to the radio a little too loud
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
06-21-2007, 11:42 AM | #11 |
Thanks. It doesn't bother me too much because I don't drive it often. But if the wife ain't happy, ain't nobody happy.
