Old 06-06-2007, 04:21 PM   #1
1969k10stepside
Question Any ideas on removing a fill plug?
Well,now that the motor is in the truck I'm going over everything tightening down bolts that came loose or were never tightened.I'm also topping off the diffs with fluid..I got the front plug out pretty easy with the crescent wrench but the back dont wanna come off.Why can't they just use a regular bolt?They have to use those damn square plugs....Any ideas?I tried the big crescent wrench and it's too big but the little one doesnt seem to do the job.I found a metric wrench that fit on there and I think I bent the wrench before the plug budged...It's the fill plug on the side of the diff case near the pinion on the 12 bolt rear...
1969k10stepside is offline   Reply With Quote
Old 06-06-2007, 04:45 PM   #2
bowtier
Nobody rides free
bowtier's Avatar
Re: Any ideas on removing a fill plug?
It's a square hole right? Or a square nut? I just used the ratchet extension to fit in mine. (the square hole)
'71 C10 LWB 400SB/350TH
'86 K2O LWB 350SB/400TH-6" tuff country lift, Shackle flip - plow truck
'06 HHR - wifes wheels
'01 Blazer - daily driver
"It's better to burn out than it is to rust."
-Neil Young
bowtier is offline   Reply With Quote
Old 06-06-2007, 05:42 PM   #3
CrashEd
72 chevy
CrashEd's Avatar
I use air tools for everything just weld up a square box out of like 3/8 steel to fit then weld a big nut on the end then you have a ready made adapter for ither air or a big braker bar.
Ed
CrashEd is offline   Reply With Quote
Old 06-06-2007, 08:26 PM   #4
eedgell
It's the air up here
eedgell's Avatar
As a last ditch effort, you could try just a little heat from a torch. Works wonders some times. Not too much though, dont want to cook anything inside.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-06-2007, 08:48 PM   #5
Billla
Billla's Avatar
Hit it briefly (and carefully) with a torch, then beeswax - or WD-40 if you don't have any beeswax
Billla is offline   Reply With Quote
Old 06-07-2007, 12:10 AM   #6
Twistedsteel
Twistedsteel's Avatar
spray it with some hairspray and then rub some ice cream on it.
Twistedsteel is offline   Reply With Quote
Old 06-07-2007, 12:37 AM   #7
Billla
Billla's Avatar
Then slap it with a dead walleye and...
Wait...that's how I got my ex-wife to remove her...
Old 06-07-2007, 12:45 AM   #8
CrashEd
72 chevy
CrashEd's Avatar
Don't use chocolate ice cream. Use strawberry and eat all the chocolate get a good sugar high going then spray with hairspray and jerk away.
Ed
Last edited by CrashEd; 06-07-2007 at 12:46 AM. Reason: spelling i think i got some right
Old 06-07-2007, 08:30 PM   #9
eedgell
eedgell's Avatar
Throw your purse at it Alice!
Eric
Old 06-07-2007, 09:56 PM   #10
1969k10stepside
Ended up getting a socket on it and used a breaker bar and finally it came loose.Many many bottles of oil later the differential is full
Old 06-08-2007, 09:51 AM   #11
Yukon Jack
Post Whore
Yukon Jack's Avatar
Glad it finally came off. They do take alot of fluid don't they! A couple years ago I bought a 5 gallon bucket of gear lube, that sure has been handy to have as I've worked on the K20 and K5. Sure beats working with a bottle too, I just stick the hand pump in the bucket and wear my arm out pumping.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-08-2007, 10:31 AM   #12
1969k10stepside
Yeah,it took quite a bit.Thankfully the plug isnt higher! I coulnt really get to it with the shock there so I had to get a funnel that bends (made of plastic) to use to fill it up.I dont know exactly how much it took but it was more than the front.The best part is I dont see any leaks under it
Old 06-08-2007, 06:14 PM   #13
msgross
msgross's Avatar
does the rear fill the axle tubes as well as the center? glad to see that you ate your Wheaties and got it off. Mine came off easily, even had the red tag warning about limited slip on it...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-08-2007, 07:31 PM   #14
1969k10stepside
I believe it fills up just the center. I went out and seen a tiny puddle under the rear axle but a bolt on the cover was loose.I tightened it so that problem should be solved now.
Old 06-08-2007, 09:56 PM   #15
eedgell
eedgell's Avatar
Was it run very long that low on lube? If so, might want to pull the cover and check for wear?!
Eric
Old 06-08-2007, 10:02 PM   #16
1969k10stepside
When I installed the lift I took the axles apart to where it was just a housing,installed all new bearings,seals,etc.Set the axles up properly.The front wasnt like the back though.It needed a new ring and pinion.Anyway so I just have had some light coats of oil on it from when I assembled everything.The truck hasnt left the garage so it didnt rust.I just up till this week never filled them up.Now that the truck is close to running,it was time to fill them up.
Old 06-08-2007, 10:06 PM   #17
eedgell
eedgell's Avatar
Sorry, my bad. I should follow more closely.
Eric
