Old 06-06-2007, 05:30 PM   #1
kahmke69
kahmke69's Avatar
Junkyard Posi
Today I found a 71' chevy truck in a junkyard.
I read the glovebox panel and found it has factory posi.
How much do you think its worth?
It seems to be in really good shape.
There were no metal shavings and the gears almost looked new.
Just looking for some opinions.
Also could I get some pictures of a factory Posi too?
kahmke69 is offline   Reply With Quote
Old 06-06-2007, 05:36 PM   #2
71tahoe
71tahoe's Avatar
Re: Junkyard Posi
I'd like to find one for $100-$250 but I think it would go for more.
Check out this in the parts.
http://67-72chevytrucks.com/vboard/s...d.php?t=227160
71tahoe is offline   Reply With Quote
Old 06-06-2007, 05:46 PM   #3
kahmke69
kahmke69's Avatar
Re: Junkyard Posi
it wont?
i also have a 68' gmc short bed
stupid question: whats the difference
between a dana 44 rearend and a 12 bolt
the gmc has a dana
the posi wont work in the dana will it.
Old 06-06-2007, 05:53 PM   #4
jgrh64
Prestige member Old Farts Club
jgrh64's Avatar
Re: Junkyard Posi
Originally Posted by kahmke69 View Post
it wont?
the gmc has a dana
different manufacturers
Hey sombodys gotta do it!
jgrh64 is offline   Reply With Quote
Old 06-06-2007, 06:00 PM   #5
kahmke69
kahmke69's Avatar
Re: Junkyard Posi
just wonderin
i have a spare 12 bolt axle
is either one better
than the other
12 bolt or Dana 44
Old 06-06-2007, 06:01 PM   #6
dubs68SWB
dubs68SWB's Avatar
Re: Junkyard Posi
The dana 44 is a 10 bolt with a 8.5 ring gear and the 12 bolt has a 8.875 ring gear. The 10 bolt dana 60 is 3/4 ton (even though you didn't ask).
'68 Chevy SWB with 460 BBC
Muncie M-22 and Eaton posi rear w/ 3.73's
Corvette rallys with mini derby
caps
Sick horsepower and torque
dubs68SWB is offline   Reply With Quote
Old 06-06-2007, 06:01 PM   #7
71tahoe
71tahoe's Avatar
Re: Junkyard Posi
Dana 44 has 8 1/2 ring gear.
12 bolt has 8 7/8 ring gear.
No way the carrier is the same.
Old 06-06-2007, 06:02 PM   #8
dubs68SWB
dubs68SWB's Avatar
Re: Junkyard Posi
just wonderin
than the other
12 bolt or Dana 44
I'd go the the 12 bolt
caps
Old 06-06-2007, 06:03 PM   #9
jgrh64
jgrh64's Avatar
Re: Junkyard Posi
isn't the GMC dana a leaf spring rear and most 12 bolt trucks coil ?
Old 06-06-2007, 06:04 PM   #10
dubs68SWB
dubs68SWB's Avatar
Re: Junkyard Posi
GMC also got all of GM's stuff that Chevy passed on...........OUCH!
I'm sorry and totally kidding!!!!!!!!!!
caps
Old 06-06-2007, 06:12 PM   #11
kahmke69
kahmke69's Avatar
Re: Junkyard Posi
i have plenty of spare parts from when i bought my 4x4
im thinking about putting it toghether as a fun truck
so which rear end would be better again?
Old 06-06-2007, 06:16 PM   #12
cdowns
cdowns's Avatar
Re: Junkyard Posi
as far as the junkyard rear is concerned i'd offer the yard $50 and if you cant use it sell it on ebay or craiglist for $300
Old 06-06-2007, 06:18 PM   #13
kahmke69
kahmke69's Avatar
Re: Junkyard Posi
if i swap rear ends
i could use it in the gmc
but if the dana is better i might buy it and sell it
maybe
what do you think about those PowerTrax type lockers?
or should i just buy an eaton or somthing like that?
Old 06-06-2007, 06:20 PM   #14
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: Junkyard Posi
The 12 bolt is usually the preferred differential.
Here's a website with some good info. http://www.offroaders.com/info/tech-.../axlefacts.htm
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-06-2007, 06:30 PM   #15
dubs68SWB
dubs68SWB's Avatar
Re: Junkyard Posi
There has been quite a few link (threads) lately on posi rearends and the power trax. Do some site searches and you'll find all kinds of info that has been posted lately.
caps
Old 06-06-2007, 07:54 PM   #16
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: Junkyard Posi
...and don't forget there were some dana 60 1/2T rearends...both coil & leaf models...most were '66 & earlier...not full floaters like the 3/4T.
PICKMUP is offline   Reply With Quote
Old 06-07-2007, 07:08 AM   #17
Re: Junkyard Posi
The Dana44 rear is a great axle.It`s what`s in 4wds and they hand alot of abuse.I`d keep whatever I had.I wouldn`t swap one for the other.They both work fine.I built a pro=street shortbed and went up to a coil Dana60 with Mark Williams 5-lug outers.
I bought a posi for $175.But,I`d give the junk man $50 like cdowns said.
Old 06-07-2007, 06:46 PM   #18
kahmke69
kahmke69's Avatar
Re: Junkyard Posi
Old 06-08-2007, 08:35 AM   #19
msgross
msgross's Avatar
Re: Junkyard Posi
I paid $35 (+$10 for the torch job) for my junyard posi 12-bolt but that was at a large JY that had set prices. It was a 12-bolt coil out of a 69/70. I'm adding spring perches and getting ready to put it under my 4x4.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-08-2007, 09:53 AM   #20
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Junkyard Posi
Fred T, that link is awesome. They have a ton of good info there.
hgs_notes is offline   Reply With Quote
