Old 06-06-2007, 07:58 PM   #1
RedZ71
Junior Member
RedZ71's Avatar
question about my next task...
this weekend, i plan to change the rear oil seal on my TH350. im pretty clear on the actual changing of the seal... but how many quarts of new tranny fluid do i need to pick up?
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 06-06-2007, 08:11 PM   #2
OJOE
Crew Cut
OJOE's Avatar
Re: question about my next task...
if you use a lift (or jack up level) you will loose less than a qt
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-06-2007, 08:15 PM   #3
70rs/ss
70rs/ss's Avatar
get the @$$ in the air and you won't loose any or very little.
70rs/ss is offline   Reply With Quote
Old 06-06-2007, 08:40 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
totallyagree.
Are you swaping out the bushing in the tail shaft too? If not, the seal will probably fail again fairly soon.
