Old 06-06-2007, 09:55 PM   #1
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Headlights info???????
Can you buy a single headlight, combined hi/low beam, to fit inside a double headlight frame?
I want the other headlight space for my ram air intake....
Thanks!
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 06-06-2007, 10:14 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Headlights info???????
the outter headlamp is a hgh/low already... so yes.
Old 06-06-2007, 11:25 PM   #3
WinDancer
WinDancer's Avatar
Thanks!
That opens a ton more options for me
Dave
Old 06-23-2007, 07:19 PM   #4
WinDancer
WinDancer's Avatar
My new LMC catalogue came and as I was going through it I noticed that the headlights they sell for 69 GMC 4 headlight systems are EITHER hi or lo beam only?
Dave
Old 06-23-2007, 07:24 PM   #5
john
member #16
john's Avatar
They are high-low only because the inner has a single element and the outer has two elements.(high-low)
john is offline   Reply With Quote
Old 06-23-2007, 08:31 PM   #6
GMC Jim
GMC Jim's Avatar
The original GMC headlights were PAR-46. Outer lamps -#4002; hi beam 55 watts, lo beam 37.5 watts. The inner headlights were #4001; lo-beam 37.5 watts. I don't believe that either of these (non-halogen ) are available. Replacements are halogen #5006 hi beam 35 watts; lo beam 35 watts and #5001 hi beam 50 watts. The #5006 are somewhat dim - 35 watts. There is available a lamp with an H-4 bulb- 60 watts hi beam and 55 watts lo beam. Cost is #15.00+each. Have seen these in JC Whitney catalog and should also be available thru your local parts houses. Seems like you would have to use the lamps with an H-4 bulb for adequate lighting
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal).
GMC Jim is offline   Reply With Quote
Old 06-23-2007, 10:43 PM   #7
GMC Jim
GMC Jim's Avatar
JC Whitney Part #SA9319P - $15.99 each. Replace outside lamps only with these high output lamps. Web site indicates these lamps are for Off-Road use only; however the 60/55W is D.O.T approved. 100/55W, 100/80W and 130/90 H4 bulbs are available for off-road use.
Old 06-24-2007, 09:00 PM   #8
WinDancer
WinDancer's Avatar
Great, thanks for the info. I can go back to planning my new grille
Dave
