Old 06-06-2007, 11:19 PM   #1
roughedup72
roughedup72's Avatar
need driveshaft length.
Well my th350 crapped out on me today so Im putting in a 700r4 tomorrow. What all do I need? my truck is a long bed with a two peice driveshaft how much do I need to shorten the driveshaft? and will the speedo cable reach or do I need a longer one?
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 06-07-2007, 07:47 AM   #2
Orange
Licensed to Thrill!
Orange's Avatar
Re: need driveshaft length.
If you are lucky, the speedo cable will be JUST long enough to reach, but I still need to get a new one, because it is under a tight pull.
The drive shaft really depends on the shop I think.
Mine was a SWB swap, so I can't tell you for sure, but my drive line shop asked that I give them the dimension from the tail seal of the transmission to the center of the rear end yoke (which is the flat half with the girdle off).
If you "schedule" getting it done, you should be able to have the drive shaft turned around in one day...I did.
Other than that I needed the fluid, and a Bowtie Overdrives TV Made EZ kit.
I already had a Lokar linkage on it, so I can't tell you anything there.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 06-08-2007, 07:07 AM   #3
roughedup72
thanks Orange.
