Old 06-07-2007, 08:41 AM   #1
freak812
freak812's Avatar
66 gmc axle swap
Hey guys, Im new to the club and new to these older trucks. All the info I found on here so far is freakin awesome.. I have a question about swappin axles in my dana 44...What kind of axles do i need to use to go down to a 5 lug rear end?? I have a rearend from a 77 chevy sittin here, will they work and how do i change them???
freak812 is offline   Reply With Quote
Old 06-08-2007, 12:16 AM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Re: 66 gmc axle swap
Welcome to the forums.
For the GMC trucks, it should have leaf springs in back, if so swapping to a newer 5 lug axle should be a breeze. I know a guy here in town that did this on his '63 GMC (first year for leaf springs).
Now if your truck is a canadian GMC (which has trailing arms), then pick up a '71-'72 Chevy C10 rearend. The only difference in axles is there is 1 extra inch at each end of the axles. Same as for the '73+ trucks axles.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 06-08-2007, 12:33 AM   #3
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
check the leaf perches, cut weld new if needed, bolt in. you might need to reduce the or correct the brake line fitting to the wheel cylinder.
trkklr77 is offline   Reply With Quote
