Junior Member
front drum
I ve never had a vehcile with front drums. Do the from drums come off like a rotor? Do you just remove retaining nut and cotter pin then pull off? Thanks
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 06-07-2007 at 12:24 PM. Reason: spelling |
Son of a gun
Re: front drum
Yeah, if the rivets are still holding the drum onto the hub. Back the brake shoes off as much as you can, take the cotter pin out, the castle nut off, wiggle the hub/drum a little to push the outer bearing out enough to grab it out, and pull the whole hub and drum assembly off at one time.
Bill BEATERS ARE NEATER |
Re: front drum
I like to knock the rivots off though to make them easier to remove, I like to knock the dust out every oil change.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
