Old 06-07-2007, 03:09 PM   #1
blaznhot_23
blaznhot_23's Avatar
67/68 front clip on 69-72 c10
I have been searching high and low in so cal for a 67/8 c10. It seems lately i have been coming up with nothing but I have come across the 69 and newer style a little easier. My question is if you have a 69-72 model can you get a pretty close/ acceptable fit with a aftermarket front clip (hood, core support, fenders, etc.) or should i just keep hunting for a solid 67/8 complete truck??? thanks in adbance for the help
blaznhot_23 is offline   Reply With Quote
Old 06-07-2007, 03:24 PM   #2
sb69chevy
sb69chevy's Avatar
Re: 67/68 front clip on 69-72 c10
I'm kicking around doing the same. I like the 69/70 clip, but to me the 67/68 clip looks killer. I believe you'd be better off finding an original clip w/ regards to fit, but I'm no expert on body work.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 06-07-2007, 03:25 PM   #3
1LoC10
Insert Title Here
1LoC10's Avatar
Originally Posted by Mt Man Chad View Post
Yes Fender's Hood & Core support can be swapped!
I dont think thats his question....... I think he wanted a factory 67/68 clip, but will settle for after market 69-72 if the fit is good on the aftermarket parts
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 06-07-2007, 03:46 PM   #4
3/4tonterror
3/4tonterror's Avatar
it all bolts right up.i just did it.my 71 looks like a 67 now.
3/4tonterror is offline   Reply With Quote
Old 06-07-2007, 04:12 PM   #5
1lowdiesel
1lowdiesel's Avatar
yup everything bolts right up just use the fenders, grille, hood, and support obviously. i'll be doin mine soon enough. i'd say just buy the re-pop stuff if you can't find stock stuff.
have you checked on craigslist?
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 06-07-2007, 04:31 PM   #6
BigMike
BigMike's Avatar
I'd stay as far away as possible from the repop stuff. It's thinner steel and is not made as well for the most part. The original stuff will be much heavier and thicker and will not dent as easily. I just kept an eye out, finally met a guy at the Pomona swap meet that had a front end at home. I met with him and picked it up for $350. They are out there, you just need to be patient. Also, call on any listing on craigslist that says parts for the 67-72 trucks, I have found so many parts that way, just asking what else they have.
Mike
BigMike is offline   Reply With Quote
Old 06-07-2007, 04:42 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I agree with mike... I'd rather have original metal, the repro stuff takes a LOT of work to fit it right, and once it's on, it gets dented easily.
Old 06-07-2007, 05:08 PM   #8
streetstar
streetstar's Avatar
Yes, but when you add it all up (69-72 truck) plus clean 67-68 sheetmetal, plus paint, plus a few hundred hours of your labor-- well, you get the idea
If you are going to be building a frame-off style , 15-20 k showpiece, you probably aren't worried about those details, but if you're wanting a driver, it would definitely be easier to keep looking for a 67-68 and maybe expand the search to neighboring states.a little.
But if you do the later model thing, keep in mind that 71 and 72's have 5 lug wheels and disc brakes (also a plus)
streetstar is offline   Reply With Quote
Old 06-07-2007, 07:44 PM   #9
dan42
dan42's Avatar
There's a decent '68 front clip in a Santa Maria junkyard if you're interested - let me know and I'll tell yhou where it is.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 06-07-2007, 07:51 PM   #10
blaznhot_23
Mike
when does the pomona swap meet happen??
Old 06-07-2007, 07:54 PM   #11
blaznhot_23
the question is is it still up there???
Old 06-07-2007, 08:20 PM   #12
GREASEMONKEY72
GREASEMONKEY72's Avatar
theres nothing like the original steel, fit and quality
where in the 661 are you?
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 06-07-2007, 09:00 PM   #13
blaznhot_23
^^^ santa clarita by magic mtn
Old 06-07-2007, 11:45 PM   #14
dan42
dan42's Avatar
I drive by it a couple times a day - it's still there - a white longbed.
Philippians 4: 6-7
Old 06-07-2007, 11:46 PM   #15
dan42
dan42's Avatar
There's also a '70 front clip right on highway 1 that can be had for free as well, but someone's already taken the doors.
Philippians 4: 6-7
Old 06-08-2007, 12:38 AM   #16
Louis72
Louis72's Avatar
This is my 72 c10. I found a 68 front clip and with a little modification and alot of help was able to use 72 core support(didnt want to mess wth a/c ect). Worked out ok. Love the 68 front. Good Luck.
Louis72 is offline   Reply With Quote
Old 06-08-2007, 12:57 AM   #17
ohmsc10
ohmsc10's Avatar
I am in my 3rd week of this same build. It is taking a lot more effort to get the new metal (mostly the new doors) to fit to the original but it is better than dealing with rust repair.
71 Bagged Longbed
ohmsc10 is offline   Reply With Quote
Old 06-08-2007, 01:12 AM   #18
dan42
dan42's Avatar
Louis72, that is a beautiful truck!!!!
Philippians 4: 6-7
Old 06-08-2007, 02:36 AM   #19
blaznhot_23
pm me the info on this...thx
Old 08-18-2019, 05:12 PM   #20
67lq4
this is a old post...but i have a 67 and im interested in putting 69-72 front end on mine...i like the look ofthe newer front ends more then the 67-68...has anyone done this or have any pics of it???
67lq4 is offline   Reply With Quote
Old 08-18-2019, 05:27 PM   #21
landarts
landarts
I did this with original parts from a 68 c30. Make sure to get the right rubber supports for the radiator core support, they are different than the 69-72 rubber supports.
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
Old 08-19-2019, 02:00 PM   #22
landarts
landarts
Here is a picture for 67lq4, wanted to see how my swap went. It is a 72 Cheyenne with a 68 front clip.
68 Second Chance
72 K10 Custom
71 K10 Custom
71 GMC Jimmy CST
72 Blazer
70 Blazer
Old 08-19-2019, 02:10 PM   #23
67lq4
ahhhhh looks good butttt i want to do the total opposite haha i have a 67 and want to put on a front from a 72 i think the 70-72 looks better then 67-68.... i think my 67 would look alot more like the newer models with the newer model front....
Old 08-19-2019, 02:30 PM   #24
67lq4
sooo what would i need to put a 69-70 grille on my 68??? hood? grille and chrome grille surround???
Old 08-19-2019, 02:59 PM   #25
CK67
67 c30 core support and fenders rotted. Decided to make it GMC, tough finding parts went with LMC. Not easy a lot of fitting and grinding finally got body lines descent . Be prepared to get frustrated and pissed off but it can be done with patients and alcohol.
CK67 is offline   Reply With Quote
