Old 06-07-2007, 06:50 PM   #1
Ricks1971
Ricks1971's Avatar
longbed to a shortbed?
I just shortened a longbed to a shortbed and my question is will I have to move the bed mounts or will the short bed fit without moving them? I know I have to take the front mount off.
Ricks1971 is offline   Reply With Quote
Old 06-07-2007, 08:40 PM   #2
Goodguytrucks
Re: longbed to a shortbed?
I am pretty sure all you do is remove the front bed mount and you have to move the rear cab mount. I am in the process of doing the same as you and I haven't tried putting the box or cab on yet......still working on the suspension
Goodguytrucks is offline   Reply With Quote
Old 06-07-2007, 09:05 PM   #3
Ram-Man
Ram-Man's Avatar
search the faq, or go to earlyclassic.com and look in tech. The front bed mounts gets tossed and the rear cab mount moves back 12". 12" out from under the cab area and 8" off the back of the frame.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
Old 06-07-2007, 11:35 PM   #4
Ricks1971
Ricks1971's Avatar
Thanks, That's the place I went to get the metal to box the frame. Really easy! I haven't cut the back of the frame off yet as I wanted to make sure The box fits.
Old 06-07-2007, 11:39 PM   #5
brak
brak's Avatar
Check the Low Buck Build.
it was shortened early in the process, with alot of pictures and details.
http://67-72chevytrucks.com/vboard/s...d.php?t=223158
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 06-08-2007, 01:37 AM   #6
wibilly
wibilly's Avatar
not to be a smart a$$ but you should have had that answer before you made your first cut!
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-08-2007, 01:45 AM   #7
poorboy
poorboy's Avatar
rockcrln just did his. Read his build and maybe it will help.
poorboy is offline   Reply With Quote
Old 06-08-2007, 01:47 AM   #8
poorboy
poorboy's Avatar
Here's a link to it.
Old 06-08-2007, 10:59 AM   #9
Ricks1971
Ricks1971's Avatar
I used this site and info to shorten the frame.
http://www.earlyclassic.com/tech.asp...20No!-Shortbed
That's done just like the article states really easy. My question is aside from loosing the front bed mount do you have to move the other bed mounts abit to have the short bed fit or will it fit correctly.
Old 06-09-2007, 05:29 AM   #10
wibilly
wibilly's Avatar
looks like you should be good to go. when i first read this i though you were saying you shortened your box. remove front mounts and bolt your short box on. hope it works out well for you!
