Old 06-07-2007, 06:57 PM   #1
chevyboy55
chevyboy55's Avatar
Door Weatherstriping Question
My son & I put new door weatherstriping in his 72 & they do not close very well(as was expected) how long has yours taken to compress & any tricks to get it to do so(other than time?)
Great minds think alike,So do ours
chevyboy55 is offline   Reply With Quote
Old 04-29-2008, 08:16 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Door Weatherstriping Question
ttt
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-29-2008, 08:31 PM   #3
Putter
More Cowbell....
Putter's Avatar
Been waiting on mine to "self-adjust" for over a year now, and they are pinch-on ones from the junk yard.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 04-29-2008, 10:46 PM   #4
68gmsee
Active Member
68gmsee's Avatar
I did some long time ago. Memory is fuzzy but, here in Texas during the summer it doesn't take very long. If I remember correctly just a few weeks.
I did the hood to cowl seal last month and it was pretty tight for the first week or so. It was lifting the back of the hood up. But a few days of warm weather and driving the truck, made it settle down. It fits pretty good now.
I'm thinking of doing the door seals on the GMC in the very near future. I already have them but just haven't got around to installing them.
One thing I always do when I install rubber stuff is to use ArmorAll on them. Don't know if this helps in softening up the rubber, but, I'm a firm believer in that stuff. Kept a lot of my vehicle dash pads and other plastic/rubber parts from cracking and drying up.
68gmsee is offline   Reply With Quote
Old 04-29-2008, 11:16 PM   #5
gcburdic
Restoration Virgin!
gcburdic's Avatar
I got another question....I am ready to install the door seals, but with a test fit they are too long....how much of a gap do I leave or should I seam them together??...I've seen somewhere to cut a 45 degree angle at each end when seaming them together...is that for air release?? Where should the seam be?? under the sill plate, back of the door, front of door?? (Obviously, I really don't know what the hey I'm talking about, but as you can see I need HELP!!!!)
Geoff with a G
Old 04-30-2008, 02:17 AM   #6
Sammy
I put my seams under the sill plate they were only about 2 or 3 inches too long.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-30-2008, 01:56 PM   #7
70c10
67-72 Addict!
70c10's Avatar
gcburdic- I believe the factory location for the air release was on the front of the door between the hinges. You can use an awl to pierce holes every 4" in the rubber to help the door close easier and not be seen. The 45° cut is at the top front corner of the door frame. I highly recommend using the S-10 rubber instead of the factory style.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-30-2008, 07:29 PM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Hey 70c10,
I just remembered I saw the air release location in the factory assembly manual too....thanks....
that's a great idea about using the awl to pierce holes....I'll definitely do that...
I appreciate your input about the S10 rubbers, but I guess I'll use what I got right now, but if I change my mind....what year S10 rubbers should I use??
Thanks again
PS....Sammy...I think I'll put mine under the sill plate too.....thanks
Geoff with a G
Old 04-30-2008, 07:44 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Originally Posted by gcburdic View Post
Hey 70c10,
Thanks again
Look on page 2 of this thread for some pics! http://67-72chevytrucks.com/vboard/s...ther+stripping
You won't need a seam with the air gap.
Jim
