Old 06-07-2007, 07:43 PM   #1
joe b
Question frame
I have a ? will a79 c10 frame work under a70 c10?
joe b is offline   Reply With Quote
Old 06-07-2007, 07:45 PM   #2
1969k10stepside
Re: frame
Frame is longer,frame is different so a body lift would be needed and then it would basically look like a 4wd......New body mounts would have to be made too.
1969k10stepside is offline   Reply With Quote
Old 06-07-2007, 07:52 PM   #3
joe b
Unhappy Re: frame
thanks for the fast reply
Old 06-08-2007, 12:19 PM   #4
wyatt earp
Re: frame
i saw a truck near where i work, looked to be a '75? someone had put a newer 4x4 frame under it . although the front end lined up right the rear axle sat about 6-8" to far back in the wheel wells (vary obvious to see). just my 2 pennies.
wyatt earp is offline   Reply With Quote
Old 06-08-2007, 11:47 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: frame
a 4X4 isn't too bad, you can do a bodylift and not look retarded.
