Active Member
wtb inline 6 mounts
seeing if anyone has some laying around i think i threw mine away
the mount that bolts to the frame thanks |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: wtb inline 6 mounts
Which 6cyl.....250 or 292? AFAIK the 250 frame mounts are the same as the SB ones. If you need them for a 292 I have'm. PM me if you're interested....got the SB ones too.
![]() Join Date: Jan 2007
Put me next in-line..... If laidout passes I'm interested in the 250 mounts a complete set. Engine steel mounts, rubber motor mounts, and frame saddle mounts. Thanks!!
![]() ![]() ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
Active Member
ill pass for now i got a ls1 i think im going that rought
60-66 Nut
All I would have are the frame mounts.....I just need to verify that they are the same as the SB ones. I'm pretty sure they are, I just don't remember for sure.
60-66 Nut
Everything I've found says that the frame mounts for the 250 engine are the same as the SB ones. PM me if you need some.
Thanks Captainfab,,, but I need a complete set. And yes your right the inline six frame mounts and the 350 frame mounts are the same. Thank you, for check!!!!!!!!!!
Can you P.M, me with cost and shipping to Ft. Worth TX 76133. And a pic please to make sure its the 69-72 model mounts, I need them to work with certain brakets I have which the later year mounts will not work with.
