06-07-2007, 11:45 PM | #1 |
71 suburban th400 to 700r4 swap
I have a 1971 suburban with a 402 big block and a th400 tranny.
Has anyone got any info on the difficulty of a th400 to a 700r4 tranny swap? |
06-08-2007, 12:58 AM | #2 |
Designated Grumpy Old Man
Re: 71 suburban th400 to 700r4 swap
Welcome to the board. There is a ton of info here. This link is in the FAQ forum aka Frequent Ask Questions. Hope it helps.
http://67-72chevytrucks.com/vboard/s...ad.php?t=33266 oldiron suburban moderator
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
06-08-2007, 08:43 AM | #3 | |
Rottenwood Garage Member
Easy and quick As mentioned above.........if you can figure out how to "search" there is a ton of info on here about this. I never seem to be able to get anywhere but I think you have to type it in "word perfect" Who knows??? Last edited by 72freak; 06-08-2007 at 08:43 AM. |
06-08-2007, 09:39 AM | #4 |
///Relaxed Atmosphere
it is as easy as stated by 72freak. did mine about 4 years ago and still going
72 Suburban 64 Chevy short fleet 04 Chevy Colorado Sport Reg Cab 2012 Chevy Avalanche 2003 Chevy S10 Blazer Xtreme http://www.hubgarage.com/mygarage/RA_Jeff 64 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=295915 |
06-14-2007, 11:12 AM | #5 |
700r4 is longer than th400, right?
06-14-2007, 12:20 PM | #6 |
AttentionDeficitDisorder
you just just need a lock up kit in your 700r4 for the converter and get a later one if you can out of an early 90s pickup/van. the 700r4 is the same length as a longtail th350, im not sure how youd get an extra spot on your shifter/shift indicater, but you could go with an aftermarket lokar floor shifter.
06-17-2007, 05:26 PM | #7 |
700r4.com use to sell new shift indicators that had the correct pattern on them. befor eevery one was selling wiring kits for the lock up converter we use to just get a break switch from a newer truck with the extra wire conection and wire it to the trans so that the converter would unlock when you hit the brake. Funny thing is now if you do a search for how to do it you cant find it. 700r4 use to have a tech right up on there site when they were first starting out on how to do it this way but now they sell the kits.
Earl 68 2500 4x4 GMC Burb |
