Old 06-07-2007, 11:55 PM   #1
Angelse68cal
Cochino_Racing_909
Angelse68cal's Avatar
Need Some Tech help
I have a 1972 GMC Jimmy 4x4 I am Building i just got everything dialed in and now my problem is.....
1. When Driving it goes to a certain speed and when I let of the gas it sounds like one Rock and a Bell is tubling in my transfer case. Does anyone know what this might be.
2. I also Noticed that the Front drive line turns while I am driving even when its in 2 HI But If I grab the drive shaft throught the Cover it stops so it is free wheeling but it still spins..... I would like to know why and is this normal.
Angelse68cal is offline   Reply With Quote
Old 06-08-2007, 09:39 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Need Some Tech help
Not sure about your t/c noise but it doesn't sound encouraging. Have you drained the gear oil to see what it looks like and whether there are any metal pieces in it?
It's normal for the front driveshaft to turn some even when it isn't engaged.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-08-2007, 10:14 AM   #3
vtblazer
vtblazer's Avatar
If one of the front hubs is partially engaing it can sound like the t-case is about to drop out, may not be it but check to be sure.
It's happened to myself and a friend that has a ford, poor guy was certain he had busted his t-case while wheeling with us and was about ready to yank the thing out...
vtblazer is offline   Reply With Quote
