Old 06-08-2007, 01:08 AM   #1
CJ5 Convert
CJ5 Convert's Avatar
TH350 leak and NP205 leakier. HEELLPPP!!
Hey folks, I posted my new blazer earlier today (1969 K5 CST 4WD) and am now getting to post my real first call for help. The TH350 pan is leaking from every bolt and crevice and the transmission dipstick shows it's low. But I can't find a fill tube is this a fill from the bottom kinda deal. Also my engine is running hot but I think because the PO tossed the shroud and probably the t-stat is bad. That is however another thread , the reason I'm mentioning it is because. The transmission well is pretty warm if I just drive it around the block. Some of that may be the engine but I don't know. I'm trying to get it to stop leaking long enough for me to trouble shoot the motor. Since I am no mechanic should I just try to fill the tranny and change the pan seal and filter. Or is this something I should take to a Trans shop before something bad happens. Also the NP205 is leaking from every bolt but should I just keep putting fluid in it for now? till i get all of the other fires put out. Thanks for the help.
CJ5 Convert is offline   Reply With Quote
Old 06-08-2007, 02:21 AM   #2
CJ5 Convert
Question Re: TH350 leak and NP205 leakier. HEELLPPP!!
I just realized I guess I should have put this in the general discussion stuff on trannys and t-cases. Well I'll post it there too. I hope thats not bad manners.
Old 06-08-2007, 02:30 AM   #3
teamradrz1
teamradrz1's Avatar
Sounds like your leak may just be because it sounds like you are missing the dipstick. You can buy these at any parts store for like $10-20 bucks. there will be a hole just opposite the front corner passenger side of the the tranny. if you are laying underneath it looking up reach over that corner and you should find the dipstick rod or a hole where it use to be.
hope that helps
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 06-08-2007, 03:13 AM   #4
CJ5 Convert
I've got the dipstick I just wasn't sure if I poured fluid down that little hole if it would cause a problem as it is it is the only spot I can see to fill it.
- Jason
Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT
1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint
Old 06-08-2007, 03:26 AM   #5
krue
Designated A-hole!
krue's Avatar
That's where you fill it, the dipstick tube.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 06-08-2007, 03:36 AM   #6
CJ5 Convert
Talking Re: TH350 leak and NP205 leakier. HEELLPPP!!
THat makes me feel dumb. Cool well krue I owe you another one. Also I joined up as a supporter. Thanks again for all the help.
- Jason
Old 06-08-2007, 05:48 AM   #7
krue
Designated A-hole!
krue's Avatar
We appreciate your support, and anything I can help with let me know. If you wanna do some interesting reading, click the Index link in my sig.
www.daveramsey.com
Old 06-08-2007, 09:36 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
It's money well spent - so much good advice and information is available here and no one will ever say you asked a dumb question - truly a dumb question is one that isn't asked.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-08-2007, 10:01 AM   #9
hgs_notes
GEARHEAD
hgs_notes's Avatar
The tranny will and should be warm from even a short drive. You just need to keep it from getting too warm and that means over about 200F. The tranny cooler built into the radiator is done that way to help the fluid warm up when cold. This is more of a feature for northern climates, but they are all done the same. In fact, you don't need to use the radiator tranny cooler if you don't want to. I converted my truck from manual tyranny to auto and used an add on tranny cooler for several years, until I had some radiator work done, then they added the cooler tank to my existing radiator.
If your pan gasket leaks and you are not sure about the history of oil changes, etc. Take the truck to the local oil change shop or garage you use and have them replace the tranny oil filter. They have to pull the cover and will install a new pan gasket when they do it. The cost is usually not bad. Like $75 around here.
hgs_notes is offline   Reply With Quote
Old 06-08-2007, 10:33 PM   #10
JUSBLAZ
JUSBLAZ's Avatar
Couple of things you might need to check. One is your thermostat if he took it out that might cause your block to run hot, because the water runs through your cooling system too fast not allowing it to be cooled in the radiator. Second would be having a shroud put on, so that the fan will pull air through the radiator thus cooling the coolant. My bet is that you do both of those and you should notice a great difference.
Just my two cents
JUSBLAZ is offline   Reply With Quote
