Old 06-08-2007, 07:57 AM   #1
67Mach1
67Mach1's Avatar
Rear end Help... Brakes
I have a 5 lug rear end from a 1/2 ton 1971 chevy truck that when I purchased it I was told was a complete rear end.
Unfortunatly I puled the drums the other day and all the brake mechanisims are missing from the rear end. Well almost everything... the wheel cylinders are stillthere as well as the e- brake lines.
Is there a doner truck where I can get the missing brackets, I am sure I will use a new spring kit but from what donor or what parts store can I get the adjuster and the other items that dont come with these kits. Will the parts from a 73-87 truck fit the axle?
Soon to be selling all but one, or two... Depends on what the Boss has to say.......
67 GMC Shortbed 454 Project
more junk and most of it
is for sale
67Mach1 is offline   Reply With Quote
Old 06-08-2007, 10:58 AM   #2
BCOWANWHEELS
Re: Rear end Help... Brakes
there is no complete spring kits available..... all of them are partial kits. go figure...... i just went through this the past 3 days. better find a donor vehicle for some of the parts that arnt in the kit.
bob
BCOWANWHEELS is offline   Reply With Quote
Old 06-08-2007, 12:10 PM   #3
lowdowndirtyshame67
Slow, slow, slow...Slowrielly's!!! I don't know if they have them in your area, but O' Rielly's, Autozone, Bumper to bumper have the parts you need (although prob not in stock). You need a hardware kit and the adjuster kit. The kit from O'Rielly's for the adjuster comes with the adjuster, springs, arm and the little pivoting du-dad. The hardware kit comes with everything else. I can get part numbers if that helps...
lowdowndirtyshame67 is offline   Reply With Quote
Old 06-08-2007, 08:19 PM   #4
67Mach1
67Mach1's Avatar
Yeah, that would be great if you could... I could walk in and get them to order them or do it on line.
Thanks that would be very nice of you.
Thomas
is for sale
Old 06-08-2007, 10:03 PM   #5
BCOWANWHEELS
I,am Tellin You Orileys Nor Anyone Else Sells The Complete Spring Kits. There All Short. Order Em And You,ll See My Friend. I Just Been Through It This Week.....
Bob
Old 06-24-2007, 04:27 PM   #6
larry may
Smile Re: Rear end Help... Brakes
Bob
wow weee! Try one of the board Vendors.
The biggest problem people have, is other people
Thou shalt be cool and not hassle
Be a site supporter.
The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2
larry may is offline   Reply With Quote
Old 06-24-2007, 08:05 PM   #7
A.P.
Black 72 Chevy
A.P.'s Avatar
This is from truckandcarshop.
http://www.truckandcarshop.com/trucks60_72/t60_114.html
72 Chevy, SWB, 350engine, TH400
A.P. is offline   Reply With Quote
Old 06-24-2007, 11:09 PM   #8
EFI70Blazer
Active Member
EFI70Blazer's Avatar
Here is mine after rebuild.
The kit i got came with everthing except the plungers for the wheel cylinder, the washer on the top that goes behind the two springs, the e-brake lever, and the rod on the top with the spring on it. The rod with the spring is the black one not the orange one. Everything else was included with my kit. Raybestos puts out the kit.
By the way i did tighten up the gaps on the ends of the springs after i took this picture.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
