Old 06-08-2007, 12:37 PM   #1
1969k10stepside
Front driveshaft and header clearance???
Well,the motor is in so I put the headers on and I got out a front drivshaft and set it in place to check clearance.The header on the passenger side is about 1"-2" from the driveshaft.Do you think that's to close? If I had a camera I would take a pic and show how close the driveshaft is to the header but I dont have a camera..I think it seems too close.
1969k10stepside is offline   Reply With Quote
Old 06-08-2007, 01:17 PM   #2
Mudder
Mudder's Avatar
Re: Front driveshaft and header clearance???
Seems awlfully close. I can look at mine tonight and see. Mine on the passenger side is very close to the rear spring hanger bolt.
Mudder is offline   Reply With Quote
Old 06-08-2007, 02:07 PM   #3
1969k10stepside
Thanks,I went out and looked on the 79 K10 because I took it to the parts stash to see the damage from the limb that fell in the storm (limb bent the roll bar I had sitting outside,guess I wont use it now).The headers are close to the driveshaft but I believe they are farther away then on the 71.The 71 has about 1" of clearance from the driveshaft,and 1" clearance on the other side from the spring shackle.
Old 06-08-2007, 02:29 PM   #4
Yukon Jack
Post Whore
Yukon Jack's Avatar
If you get your springs compressed do you think it will hit - if not I wouldn't think there should be any concern. My driveshaft on my 69 K20 with the BBC is fairly close, probably 1 1/2 to 2" and it causes me no problems so far.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 06-08-2007, 04:16 PM   #5
rcflyer1234
rcflyer1234's Avatar
You wont have any problem
rcflyer1234 is offline   Reply With Quote
Old 06-08-2007, 04:36 PM   #6
1969k10stepside
It will be close.Whether it does or not...probably not for what it will be used for.My brother in law said when I'm flexing the frame while driving in a dtich it will hit.I laughed and said it wont be going through any ditches with 3:73 open carriers.
Thats good to know.Now I just have to figure how I'm gonna run the exhaust.It looks if I run above the transfer case it will be close.I might have to run it under the crossmember.
Old 06-08-2007, 10:03 PM   #7
eedgell
It's the air up here
eedgell's Avatar
The problems all around with headers. Those are for hot rods not 4x4's. Unless they are monster mud runners, I stay with the stock style manifolds. Much easier to work with.
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-08-2007, 10:36 PM   #8
Mudder
Mudder's Avatar
Mine are really simple and go over the crossmember. Two bends basically and then straight to the back of the cab.
Old 06-08-2007, 10:54 PM   #9
eedgell
eedgell's Avatar
Mudder: headers, or manifolds?
Eric
