Old 06-08-2007, 06:42 PM   #1
RyanG
RyanG's Avatar
wrong flywheel
I purchased the following flywheel p/n 12551367 from GM for my 2001 LS1 5.7L. The holes are too far apart and I need to bolt up to my th350. Can anyone tell me which flywheel I need.
RyanG is offline   Reply With Quote
Old 06-08-2007, 09:28 PM   #2
RyanG
RyanG's Avatar
Re: wrong flywheel
Well I stoped crying and made the holes longer. It should work fine now
Old 06-08-2007, 09:30 PM   #3
kwmech
Re: wrong flywheel
Uhhhhmmmm, ooookay. I would have got the correct one myself.
Old 06-08-2007, 09:35 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: wrong flywheel
http://www.nastyz28.com/sbcmenu.html#balance
Try this website
Small Block Chevy Flexplate Part Numbers
Part # DIA. Teeth Comments
471529 12.75" 153 Two-piece seal blocks, int balance
471578 14" 168 400 ext. bal, two-piece rear seal
471598 14" 168 Two-piece seal blocks, internal balance
10128412 12.75" 153 86-up, one-piece rear seal ext. balance
10128413 14" 168 86-up, one-piece seal, extra thick, HD, ext bal
10128414 14" 168 86-96, one-piece rear seal, ext. balance
14088761 14" 168 89-up 350 HO, one-piece rear seal, ext. bal.
14088765 12.75" 153 86-up, one-piece rear seal, ext. bal.
14088767 14" 168 89-up 350 HO, one-piece rear seal, HD, ext. bal
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-09-2007, 12:40 AM   #5
truckdude239
truckdude239's Avatar
Re: wrong flywheel
umm good luck with that the torque converter will slide in the bolt holes if you maded them longer just my .02cents
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
