Old 06-08-2007, 11:08 PM   #1
eedgell
It's the air up here
eedgell's Avatar
Question Dana 44 6 lug to 8 lug
What all is involved in the swap from 6 lug to 8 lug on the front Dana 44? Easy or not?
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-08-2007, 11:28 PM   #2
CrashEd
72 chevy
CrashEd's Avatar
Re: Dana 44 6 lug to 8 lug
Easy just one more step than changing a axle out.
Ed
CrashEd is offline   Reply With Quote
Old 06-08-2007, 11:46 PM   #3
1969k10stepside
Pretty simple,IMO.I believe you just change stuff from the spindle out...You re-use the 1/2 ton calipers though....Correct me if I'm wrong
1969k10stepside is offline   Reply With Quote
Old 06-08-2007, 11:59 PM   #4
eedgell
eedgell's Avatar
Yes, is that bad? So does the spindle change or not? I will get these parts at a local yard so I need to get everything I need. How much bigger are the 3/4 ton calipers?
Eric
Old 06-09-2007, 01:16 AM   #5
earl87gta
earl87gta's Avatar
Calipers are diffrent there are 2 diffrent types of spindals and hubs one had a larger barring so its best to get every thing as a whole hubs with spindles. you will also need the 3/4 back plate the 3/4 rotors are larger so you will need them for the calipers to mount too. Ill Pm you
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-09-2007, 01:50 AM   #6
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
or you can buy the spindles, backing plates, and hubs from me.
the calipers are the same size but can be minorly different yours WILL work and work fine.
the older d44 uses a smaller inner bearing but the 10 bolt and 3/4t d44 spindles are the same.
the stub shaft will inter change.
trkklr77 is offline   Reply With Quote
Old 06-09-2007, 07:28 AM   #7
msgross
msgross's Avatar
only hard part is getting the spindle off the knuckle. Take a lead hammer so that it won't mess up the spindle threads. I had to resort to PB blaster and an air chisel on all of mine. Find the least rusty donor.
Might be easier in the long run to pull the whole axle and take your time at home. The JY will torch it off for you....
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-09-2007, 08:25 AM   #8
The GM parts book lists 3/4t spindles as different,then there`s the`72 1st and 2nd design.Same as 10-bolt?That`s a new one for me.But,I never messed with those.The parts book stops at`72 also.
Definately either get the assembly starting with the stub axles like Earl said. out or the whole axle.Differences are small and will frustrate you,I garauntee.
Old 06-09-2007, 02:35 PM   #9
eedgell
eedgell's Avatar
Thanks guys. Looked at the scrap yard today and found a 44 8 lug with full time hubs with 4:09 gears for $50.00. The whole thing looks to be in pretty good shape. My 44 6 lug has 3:07 gears. Which carrier is better? My 454 BBC does not mind the tall gear, but I think something in the 3:55 range would be better all around for mpg and such. Might want to go posi or locker, is there a difference in the two carriers or not?
Eric
Old 06-09-2007, 03:48 PM   #10
msgross
msgross's Avatar
carriers are different 3.73 and up changes. How large of tires are you going to have? What rear do you have? I have a set of 3.73's (front dana44 and back chevy 12 bolt) if interested. Randy's has a lot of information and products. http://www.ringpinion.com/
The Garage:
Old 06-09-2007, 04:53 PM   #11
earl87gta
earl87gta's Avatar
I would also use your old d44 if the new one doesnt have flat top knuckles you may want to go to cross over steering some day and the flat top knuckles are worth a good peenny the jeep guys pay a $150 for the set.
Earl
Old 06-09-2007, 05:56 PM   #12
msgross
msgross's Avatar
My flattop knuckle just sold for $83 on Ebay... I was hoping for more but oh well.
The Garage:
Old 06-09-2007, 06:10 PM   #13
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
I remember back in the day when I got my Blazer and was all geared up to beef up the half ton axles with trusses and what not. Then a friend of mine insisted that I'd be happier swapping both axles to 3/4 ton and reluctantly, thats what I did. Jump ahead 3 years later...I'm a much more avid off-roader and a lot more demanding of my truck, thus I recently went to a one ton D60 front axle. My point is, if you're gonna do any serious 4-wheeling, might as well do it right the first time.
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 06-09-2007, 06:50 PM   #14
earl87gta
earl87gta's Avatar
must be the price of gas driving every thing else down. I did the same thing on my old blazer went from 1/2 to 3/4 then to 1 ton. I started to do the same thing with my brb but ended up just going to the d60 i unloaded it from the truck be for I went to work today.
Earl
Old 06-09-2007, 09:19 PM   #15
What rear do you have?If it`s an HO52 then you`ll ave to use the 4.10 ratio.You won`t find 3.07s for that rear.
Old 06-10-2007, 12:54 AM   #16
eedgell
eedgell's Avatar
I have dana 44 front and 12 bolt rear with 3:07 open diffs. 35-12.50-15 BFG muds. would love to go D60 and 14 bolt rear, but trying to save a buck, but I dont want to step on dollars for dimes either. No serious rock crawling, just staight up colorado mountians, and mud. Plus a 454 BBC and want to keep some mpg. I am thinking 3:55 to 3:73's. How much does the 35's change the gear ratio?
Eric
Old 06-10-2007, 03:27 AM   #17
earl87gta
earl87gta's Avatar
here is a good web site to help with gear choice http://www.grimmjeeper.com/gears.html
Earl
