printed circuit boards
I busted a wire running to the fuel gauge in my tach dash circuit board.Can it be repaired or does it need a new circuit board?All the other gauges work and i can tell where it is broke at if that helps.
thanks Dean |
Professional Grade
Re: printed circuit boards
Hey Dean!
I don't have any personal experience with it, but apparantly there is a cold solder type product out there that may be the ticket... Its kind of a metal impregnated epoxy that you smear on, and when it hardens, it is kind of like a solder joint in that it protects the wires from corrosion, and conducts electricity. Dunno where you'd find it either, unfortunately... Other option is to run a wire from your instrument cluster connector straight to the pole on the fuel gauge.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Get you a cheap soldering iron. Scratch the plasic laminate off of the traces and build a solder bridge across the broken trace. Get solder with flux in it to make it flow better. If you need to you can lay a small piece aof wire across it and solder that. Get som alcohol and cean the joint after you finish. Shouldn't be hard at all.
thanks guys I well try it later today.
Oh,you can't buy that new
![]() Join Date: Apr 2000
AND if you can find a rerar window defroster repair kit it's kind what russel was talking about.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
