Went to the races today with my lwb pickup with a new 383 sb. Was hoping to get into low 14s and was suprised with a 13.36 had to scramble to find a helmet. Several other very nice pickups running also. Fun Day
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears |
Member since 2000
what are the stats on the motor, tranny, rear-end. sound like good times to me, now you can keep up with 2001 SS camaros
------------------ Britney: 1970 2wd K/5 Blazer (Frame up) Jessica: 1967 2wd SWB (daily driver) Helga: 1972 4x4 3/4ton LWB (daily driver) AIM:Alexmart1 Mountain View, Cali |
its all about the +6 inches
don't it normally go I think it'll do 13's and you hardly brake into the 14's?
------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I need another Barley Pop
Good job UncleBob! That is an excellent ET. Very respectable.........
------------------ 67 SWB 4x4 - 396 BB / SM420 4 spd 8" lift / 15x14 Welds & 35X14.5 SSR's Grants Pass, OR
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" ![]() |
Nice run UNCLEBOB! What MPH did it run? Also do you have the 1/8 mile ET and MPH? What tires were you running? What was your 60' time?
------------------ 1967 C-10, 383 Stroker, TH-350, 3.73 gear, NX Hitman Nitrous Kit, 1/8 Mile, 8.77 @80mph on motor, 8.12 @ 85mph with 100hp nitrous shot. <A HREF="http://www.geocities.com/ryan98gt/67c10.html" TARGET=_blank> Picture's of my Truck</A> Burnout Video's of my Truck Engine & Drivetrain details [This message has been edited by 383 Stroker (edited April 28, 2002).] |
Way to go UNCLE BOB! 383s rock.......69
http://community.webshots.com/user/hotrodhorn |
What altitude are you at? I am just curious because I'm at 6000 ft and want to see how things compare to here.
Thanks, ------------------ 69 Chevy ProStreet, Low and wild. Check it out http://y42.photos.yahoo.com/bluzman2004
69 Chevy ProStreet, Low and wild. 78 Corvette rturnpaugh@compcams.com |
750 vac,edelbock rpm heads and maifold, i did some porting, scat crank, lunati rods and hydraulic cam 285 507, manley pistons 10.4 compression zero decked the block 2800 stall 4.57 posi The best run was 13.36 98.73 60 ft 1.905 1/8 8.463 mph 81.24 running on 275 drag radials.
UNCLEBOB, 4.57 is lot of gear for the street. Are you running a overdrive transmission? If not, what rpm does it turn at 60mph? What size street tires do you run?
------------------ 1967 C-10, 383 Stroker, TH-350, 3.73 gear, NX Hitman Nitrous Kit, 1/8 Mile, 8.77 @80mph on motor, 8.12 @ 85mph with 100hp nitrous shot. <A HREF="http://www.geocities.com/ryan98gt/67c10.html" TARGET=_blank> Picture's of my Truck</A> Burnout Video's of my Truck Engine & Drivetrain details |
Strongman Garage
![]() Join Date: Apr 2000
NICE i wanna run 13s someday with what.... i dont know
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
The track I run at is bremerton raceway which is at about 500 ft. its only about 8 miles from home so the gears arent a problem I think I turn about 3000 rpm at 60. the tires are 28 inches tall.
