06-09-2007, 08:48 PM | #1 |
Do our trucks use door key ... or same as ignition?
My ignition keys don't work on door locks. Did they have a round key for doors 1n '71? Can anybody make one based on VIN or do you have to remove or replace lock? Thanks in advance.
06-09-2007, 08:49 PM | #2 |
Re: Do our trucks use door key ... or same as ignition?
They are separate keys for the ignition and doors, that is if they are still stock.
06-09-2007, 09:35 PM | #3 |
Yes, the square key will go in the lock all the way, but it won't turn the lock. I thought maybe the lock was just froze, but you are probably right that it was a separate key. Do you recommend taking out the lock and having a locksmith make a key OR replace the cartridge OR what. Any advice is appreciated!
06-09-2007, 09:54 PM | #4 |
Sierra Grande Club
Has anyone made one key to work everything? I was thinking of doing that down the road. Is it better to keep separate keys?
I think you need to pull the code from the passenger side lock cylinder to have new key made. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
06-09-2007, 10:05 PM | #5 |
Insert Title Here
my sqare key does the doors and ignition...guess its not stock
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
06-09-2007, 10:09 PM | #6 |
Probablly cheaper in the long run just to replace the lock cylinders. I don't think they're more than 30 bucks. Just my $.02
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
06-09-2007, 10:18 PM | #7 |
Yep, a pair of cylinders are cheap at $15. Can you get to them by just taking of the inside panels?
06-09-2007, 10:24 PM | #8 | |
Sierra Grande Club
Where did you find the lock cylinders? s/t
06-09-2007, 10:27 PM | #9 |
so they originally had seperate keys?
my one key does both ign and doors
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
06-09-2007, 10:41 PM | #10 |
My 68 has the same key for ignition and locks as well.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
06-09-2007, 10:49 PM | #11 |
Hmmmm? Come to think of it, my 1967 that I had way back in 1976 only had one key that did everything and I'm certain it was stock. Maybe a bit of "finesse" is in order to get it to turn.
06-09-2007, 11:15 PM | #12 |
my 71 has 2 diffrent keys square for ingiton and round one for doors botha re gm
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
06-09-2007, 11:16 PM | #13 |
Too Many Clubs Club
I'm in the one key works both camp. My '68 was originally my dads and I still have the original key the dealer handed him.
How I installed my air bags... |
06-09-2007, 11:22 PM | #14 |
Best bet is to replace the door locks. It's simple, remove the door panel, disconect the lock rod, remove clip, and pull the cylinder out of the door. perform steps in reverse for reinstallation...
if you are gonna replace the locks, you may as well spring the extra 10-15 bucks and get a complete kit. this will give you ignition, door, and glove box, all keyed the same. I think i paid $35 for my complete set
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 06-09-2007 at 11:23 PM. |
06-09-2007, 11:22 PM | #15 |
One key should run doors and ignition, if not, something has been changed.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
06-09-2007, 11:31 PM | #16 |
Sierra Grande Club
Seems like it should only be one key. Mine has two though. I should try the PS door with the ignition key, but it’s really worn and don’t think it will work even if it is correct.
Something could have been changed on mine somewhere down the line too. It’s definitely a PITA.
06-09-2007, 11:41 PM | #17 |
Zappaphile!
Count me in the one key camp too..
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
06-09-2007, 11:42 PM | #18 |
OzarkHillbilly in Atlanta
maybe i'm thinking about cars, but I remember 2 keys, one square, one oval.
Only truck I had that used the same key was the one i bought ignition and door locks keyed the same. I also have a Freightliner lock and key for the glovebox. (ya never know what is interchangable).
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
06-09-2007, 11:57 PM | #19 |
I got replacement locks keyed for just one key to replace mine. Maybe there was a switch on them as my 70 has the two separate ones and they are the originals, I guess I thought they were all that way cause all my GM cars had the separate door/ignition setup until my 92.
06-10-2007, 12:05 AM | #20 |
fwiw, i can take the key out of the ign with it in the on position and the engine running, ill go out and start her up and lock the doors and go back inside while she warms up
06-10-2007, 12:12 AM | #21 |
My truck uses just one key for both. What bugs me is that you can't lock the doors from the inside before you shut the door, because they unlock when you shut the door. My truck has only been on the road for a week so I'm still getting used to those little details.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
06-10-2007, 12:20 AM | #22 |
Sierra Grande Club
I hate that too.
06-10-2007, 12:24 AM | #23 |
SKINNY TIRES RULE!
My '72 has one square key that opens the doors, ignition and rear hatch. It is stock.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
06-10-2007, 12:25 AM | #24 |
If you look in the owner's manual(if you have one) at the beginning it states that when the truck was purchased the dealer gives you two keys with the removed "knockouts" and each key works both the doors/ignition. My truck had two keys, door and ignition as the ignition was changed but the Suburban still had it's original locks and one key worked the ignition, front doors, and rear tailgate. In 1973 GM switched to separate keys with the oval key for the doors and the square key for the ignition.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
06-10-2007, 12:32 AM | #25 |
The Older Generation
This thread might answer some of your questions. http://67-72chevytrucks.com/vboard/s...d.php?t=213860 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-20-2019 at 02:18 PM. |
