67-72 Addict!
I FINALLY finished making my carpeted bedliner!. I've been working on it off and on for 3 months
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 06-09-2007 at 11:29 PM. |
Re: Finally finished my carpeted bedliner!
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
I like that. How are you holding it all in?
67-72 Addict!
This is what I use
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
GEARHEAD
Almost a shame to cover up the inside of a bed that looks that NICE!!!
BUT I really bo like how it turned out ![]() RJ22... ![]() |
Gosh darnit, will you stop and let me catch up, please!?!
Looks great -- ![]()
1970 C10 ![]() |
Sierra Grande Club
That looks real nice!!
![]() Now you need to take wife out for a test drive and see if it holds up!! Sort of a return on your hard work… ![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
67-72 Addict!
Thanks guys. The bed has little scratches and dings here and there. I had originally planned to just repaint the inside of the bed and flame the floor but then I wouldn't even be able to carry my chairs so I thought I wanted to try something different. When I get tired of it, it will be easy to remove!
#9 | |
67-72 Addict!
ive never liked carpeted beds but that looks nice man
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
He just did that for me......Now I get his old rubber bed mat......hehe
looks great Jim......
1997 GMC Sierra Ext 1965 Mustang |
Nice touch,just what you needed.
#13 |
sufficiently talented fool
![]() Join Date: Jun 2006
Man that looks nice!!
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
#14 |
That does look nice but what are the advantages of a carpeted bed?
-Scott- |
#15 |
67-72 Addict!
No real advantage for me because the truck is only driven occasionally and never used for hauling. It will keep my chairs from bangin' around when I go to car cruises. I just did it as a fun little project after seeing a few others on here using the pre-made kits. It's marine grade carpet that should be fine in case I get caught in the rain and the panels are easily removable.
#16 |
Tightwad
Looks very nice....just wouldn't leave out in rain....cause it seems that it would saty wet and that would lead to rusting that fine looking bed floor....but i like the carpet in the bed....makes for a nice show piece...
Eric
56 Chevy custom cab step side under construction 55 Chevy 210 68 SWB Stepside back burner under construction 72 Chevy LWB 84 CJ 7 05 Chevy 1500 Crew Cab 30X40 DOGHOUSE(shop) with many add ons |
#17 | |
Licensed to Thrill!
Man that looks great!!!
You did a superb job. Quote:
The Bedrug is actually synthetic plastic, not carpet, so it is impervious to any kind of water, gas, oil, etc. This was my before... ![]() After is like his, just the Bedrug...it doesn't wrap the side rails like that, which looks nice! DLB |
#18 |
THAT LOOKS SWEET!!! LOVE THE CARPET! I HAVE A 69 LONGBED AND RAN INTO THE SAME ISSUE OF AVAILABLITY. YOU WOULDNT HAPPEN TO HAVE THE PATTERNS FOR YOUR RUG WOULD YA?
