Old 06-09-2007, 11:03 PM   #1
sb69chevy
sb69chevy's Avatar
How to change PS pressure hose?
Finally cleaned up the underneath, and found the PS leak is coming from a cut in the pressure hose. After the cleaning, it really seemed to pour out. Guess there wasn't enough grime to keep it from dripping all over the place. Anyway, what's involved in changing this. Is it as simple as unscrew old one and screw in new one? Also, I'm hoping O'Reilly or someone has one of these?
Thanks.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 06-09-2007, 11:07 PM   #2
jojotonka
jojotonka's Avatar
Re: How to change PS pressure hose?
Yep, Just unsrew the line from the pump and the other side on the box. I bought one for my 72 at the local automotive shop. $17
I think the pump was 9/16" and the box was 5/8".. I changed both lines while I was down there. The return line was $10.
jojotonka is offline   Reply With Quote
Old 06-09-2007, 11:10 PM   #3
lbpd719
Zappaphile!
lbpd719's Avatar
and please use a fitting wrench (like you would use for a brake line). will work much better and you wont rist rounding off anything..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-09-2007, 11:15 PM   #4
sb69chevy
sb69chevy's Avatar
My return hose, I can handle. Just clamped, right? Will make sure to use 9/16 and 5/8. Any other thoughts?
Old 06-09-2007, 11:17 PM   #5
truckdude239
truckdude239's Avatar
do not use tape on new hose treads or it will leak
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-09-2007, 11:22 PM   #6
sb69chevy
sb69chevy's Avatar
Thanks for the input, guys. I really appreciate it. For those that have gotten the part from O'Reillys, etc. do you happen to have a part number so I know I'll get the right one?
Old 06-10-2007, 01:15 AM   #7
sb69chevy
sb69chevy's Avatar
Okay, so I DO NOT put teflon tape on the threads? Just confirming...trying to fix leaks, not create more for myself later. Thanks again.
Old 06-11-2007, 08:33 PM   #8
sb69chevy
sb69chevy's Avatar
Anything else? I'm hoping to get this done either tomorrow or Wednesday.
Old 06-11-2007, 08:52 PM   #9
cdowns
cdowns's Avatar
fill power steer resevoir after done and with front wheels off the ground turn lock to lock a few times to purge system and check results USE JACKSTANDS
Old 06-11-2007, 08:58 PM   #10
sb69chevy
sb69chevy's Avatar
Thanks cdowns. So do I NOT use tape? Just wanting to clarify. I've read on here in another post that I should.
Old 06-11-2007, 09:07 PM   #11
cdowns
cdowns's Avatar
no tape no sealer
Old 06-11-2007, 09:10 PM   #12
sb69chevy
sb69chevy's Avatar
Cool. Thanks again. Will try to get this done soon.
