Old 06-10-2007, 12:44 AM   #1
eedgell
It's the air up here
eedgell's Avatar
Question What is a flat knuckle?
Not to be stupid, but what is the flat knuckle? What is the other types? [dana 44 front]
1971 cheyenne k10 4 speed np 205 454 BB factory a/c
Never drink down stream of the herd!
Eric
eedgell is offline   Reply With Quote
Old 06-10-2007, 12:56 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: What is a flat knuckle?
I've been wondering about the different knuckle types too. New to the 4x4 chevy stuff and learning a lot here. Pictures would help if someone has them.
hgs_notes is offline   Reply With Quote
Old 06-10-2007, 01:19 AM   #3
kwmech
On the drivers side of a dana 44 you have the steering arm bolted to the steering knuckle. On the early 44s, the passenger side steering knuckle was flat where a steering arm could be bolted on, but it was not machined. They are sought after by the cross-over steering crowd so they can have it machined and intall their own steering arm
Old 06-10-2007, 02:00 AM   #4
eedgell
eedgell's Avatar
Mine is like that. Up to what year were they that way? You said "early".
Eric
Old 06-10-2007, 03:19 AM   #5
earl87gta
earl87gta's Avatar
1975 maybe not much later then that.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-10-2007, 08:16 AM   #6
msgross
msgross's Avatar
mine came off a 76.... rusty pic is a newer dana44 (corp 10 is the same)
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-10-2007, 09:02 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
Great, so what are open or closed knuckles?
Old 06-10-2007, 09:26 AM   #8
msgross
msgross's Avatar
oh that's easy... closed knuckle (ball and socket hip looking) is the 69? and earlier version and open is later up to 88'ish?). Closed knuckles have drum brakes and open are discs, closed have less steering radius as well and are a PITA to work on...
The Garage:
Old 06-10-2007, 09:38 AM   #9
hgs_notes
GEARHEAD
hgs_notes's Avatar
Thanks Mike!
Old 06-10-2007, 09:42 AM   #10
msgross
msgross's Avatar
no problem, I have enough axles lying around... I also have a thread somewhere about the difference between a Dana44 and Corp 10 front end... Lessons learned from my build-up...(so far!)
The Garage:
Old 06-10-2007, 05:14 PM   #11
earl87gta
earl87gta's Avatar
Mike you need to just give in and get a D60.
Earl
Old 06-10-2007, 07:17 PM   #12
msgross
msgross's Avatar
I am, to resell!
but why stop there...Go Rockwell 2.5 tons! (deuce and a halfs rock)
The Garage:
Old 06-10-2007, 08:46 PM   #13
earl87gta
earl87gta's Avatar
rock wells are to much work I would never get them under my truck.
Earl
Old 06-11-2007, 04:41 PM   #14
Zoomad75
K5Camper
Zoomad75's Avatar
A flat knuckle is what you get when you punch a solid object in a fit of anger. I was expecting the TV to break actually to which I found out Tv tubes are more solid that I previously thought. At least they are more solid than my fist!
I try not to punch solid objects anymore....
Back to the actual question. Looking at the ORD website, he lists flat top knuckles were on D44's from 76 and older. GM, Ford, Dodge and Jeep used them too, though the tie rod mounting differs between manufacturers.
The Flat top D44 knuckle can by used on a 10bolt front axle if one wanted x-over steering on it. For the most part parts from the knuckles out are interchangeable from the GM D44 to the 10 bolt.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 06-11-2007, 04:46 PM   #15
1969k10stepside
Originally Posted by msgross View Post
Closed knuckles have drum brakes and open are discs...
Not exactly true...Closed knuckle axles are '69 and older.In '70 they had open knuckle axles but they kept the drums.In 71 they finally went to discs....just a correction
1969k10stepside is offline   Reply With Quote
