Old 06-10-2007, 12:53 PM   #1
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Help with Electrical Problem
I am changing over from my step to a new sport bumper. As you can see in the pic the po had installed a set of running lights just above the bumper. When I started to check things out and undo the wiring yesyerday it looked straight forward. Those running lights were wired along with the license plate lights so that when you put on your park or headlites they came on. There was also a big ground strap from one of the bumper brackest to a bolt in the bar the running lights were on. I found the positive wire coming out of the factory tail/brake running light harness which the po had used to power the running lights and license lights. So I disconnected all the running lights and license lights left the ground strap intact. I thought I'd make sure I had power and when I pulled my park lights on I had no taillights /brake lights or factory running lights on the truck and when I checked with the test light I have no power from the wire that was powering the rear running lights and license lights. Anyone got any ideas what could be wrong? I'm thinking some kind of ground problem
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 06-10-2007, 01:43 PM   #2
Already Gone
Re: Help with Electrical Problem
ttt
Old 06-10-2007, 02:49 PM   #3
jhow66
jhow66's Avatar
Brown wire will be the hot wire when parking lights or headlights are on. Take your test light to this wire and ground.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 06-10-2007, 04:00 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Make sure your test light is grounded good... if you get no reading, then you have no power.
The lights weren't on why you were cutting them out were they? (blown fuse) or any bare spots not taped up yet? (fuse)
Old 06-10-2007, 04:22 PM   #5
truckdude239
truckdude239's Avatar
check the grounds mine didn't work and it was where the buckets contact the body ont he backside they are self grounding if you dont have a good ground no workl sand the buckets and body put back in and try thats what i did
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-10-2007, 04:33 PM   #6
John Fabris
TOTY 2006
John Fabris's Avatar
Check your fuses?
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 06-10-2007, 06:51 PM   #7
lbpd719
Zappaphile!
lbpd719's Avatar
make sure you didn't reverse one of the lights in the bucket too. Fuse would be first, but if you reversed a set, bang, blown fuse.
Disconnect EVERYTHING and check the fuse, then bring the lights up one at a time, checking the wires for any brakes or potential runs to ground.
also make sure you didn't reverse the license plate lamp.. they don't always hook up like you think they would..
Good luck..
1969 C20 LWB Camper Special - The Beater..
1998 Cheyenne V6 - 4/6 Drop - For The Son
lbpd719 is offline   Reply With Quote
Old 06-10-2007, 09:31 PM   #8
Longhorn Man
you can't reverse the wires on the lic plate light, it only has one wire.
And reversing the wires on the tail lights would just make them bright all the time.
Old 06-10-2007, 09:31 PM   #9
Already Gone
Question Re: Help with Electrical Problem
Firstly thanks for your help and suggestions guys, I always appreciate the help I get on here. Now for the rest of the story.. Seeing I wasn't having any luck with the electrical I thought I might as well stick the new sport bumper on the truck while I had some time and worry about the electrical later. Okay so me and my beautiful lady grunt and twist and push and pull and we get the new bumper installed. I deciede taht is enough for today and jump in the truck to drive it around to the front of the house. When I get there my wife is satnding on the curb waiting for me and says" Idont know if I should tell you this or not, but your brake lights are working" I shook my head and pulled the headlite switch to the opark poition and lo and behold I had all my lights I didnt have an hour earlier. I did nothing electrical to change anything, all I did was change bumpers. With the old bumper removed from the truck ,no lights, with the new bumper installed I have lights..
Old 06-10-2007, 09:40 PM   #10
Longhorn Man
Add a ground to the bed... my first truck did this. My tail lights would all go out, then all I'd have to do is lean on the rear bumper, and they'd light up.
Old 06-10-2007, 10:00 PM   #11
kwmech
Pink?
Old 06-11-2007, 01:45 AM   #12
Already Gone
Do you know why it did that? What does the bumper have to do with it?
Old 06-11-2007, 10:58 AM   #13
jhow66
jhow66's Avatar
Nothing. All he was doing was making some part of the bed make a ground to the frame. When ground was made, lights would come on. Ground your bed to the frame with a jumper wire if this is your problem.
Old 06-11-2007, 11:06 AM   #14
cdowns
cdowns's Avatar
they came from the factory with a grounding strap between the bed and the frame crossmember for a reason
Old 06-11-2007, 04:56 PM   #15
Already Gone
Originally Posted by kwmech View Post
Pink?
Oh yea !!!!!!!
