06-10-2007, 02:07 PM | #1 |
Having some grounding problems...What is the black wire for coming from new cable?
New positive cable with extra black 12ga. wire. Should that be going to the bodyside where the smallish red wire connects or is it just an auxillary 12v. line for whatever you want?
06-10-2007, 02:11 PM | #2 |
Zappaphile!
Re: Having some grounding problems...What is the black wire for coming from new cable
do you have a pic? I would hate to give you wrong information and have things make a nice pop/crack noise..
where is the small black wire, and is it on the battery clamp? is it a stand alone wire on its own? is it further down in the engine comparment? will help if I can.. just need more info
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
06-10-2007, 02:50 PM | #3 |
Re: Having some grounding problems...What is the black wire for coming from new cable?
mine goes to the pass fender junction box for the ignition,headlight,pwr when not motor not running.[ ACCESSORY]
06-10-2007, 03:22 PM | #4 |
gound it to the core support!
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque |
06-10-2007, 03:58 PM | #5 |
its all about the +6 inches
NO!!!!!!!
He said it was the POSITIVE cable. This is supposed to go to the pass fender junction box... but it is more than just as descroved above, this (if wired properly) would provide power to the entire vehicle, and nothing would work without it. |
06-10-2007, 07:51 PM | #6 |
Your fusible link hooks up to that wire, then it terminates on the junction block on the pass. fender. A 10 ga. red wire also hooks up there and runs to the alternator and fuse block.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
06-10-2007, 07:53 PM | #7 |
Do not ground it to the core support like this idiot says too. You need to read the posts better you smuck. What are you trying to do......burn the guys truck up????? Man, the nerve of some people!!!!!!! LMAO
'68 Chevy SWB with 460 BBC Muncie M-22 and Eaton posi rear w/ 3.73's Corvette rallys with mini derby caps Sick horsepower and torque Last edited by dubs68SWB; 06-10-2007 at 08:51 PM. |
06-10-2007, 08:25 PM | #8 |
06-10-2007, 09:26 PM | #9 |
Lol!
06-10-2007, 10:31 PM | #10 |
seems like most new battery cables come with that extra wire hanging off them. You can run your distro block on the fender with it or a big stereo amp etc...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
